Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 06-13-2011, 06:42 PM   #1
Holsenback
Holsenback's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger FX4 Level II
Holsenback is on a distinguished road
Default Death wobble
I have a 2003 FX4 Level II. I just got new BFG AT TA/ko's, and installed new lower ball joints, uppers were ok. I now have a severe wobble in the wheel. I've had the tires balanced 2 time and aligned 2 times.
Any ideas?
Holsenback is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-13-2011, 07:12 PM   #2
kennykenny
kennykenny's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger Super Cab
I use this vehicle for: Driving
kennykenny is on a distinguished road
Send a message via AIM to kennykenny
Default
Wheel bearing assembly with give you a nasty death wobble, check them.
kennykenny is offline   Reply With Quote
Old 06-13-2011, 09:53 PM   #3
Holsenback
Holsenback's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Default
I'm also feeling vibration in the brake pedal along with a squeak when I slightly depress the pedal.
Old 06-13-2011, 10:24 PM   #4
wrecking-crew
wrecking-crew's Avatar
Vehicle Year: 06 chevy
Vehicle Make: 88 ranger
Vehicle Model: 83 ranger 66 f100
wrecking-crew is just really nicewrecking-crew is just really nicewrecking-crew is just really nicewrecking-crew is just really nice
Send a message via AIM to wrecking-crew
Default
Sounds like a wheel hub is worn out and possibly wore the brakes . Check those.
__________________
-----The Black Bomb-----
Quote:
Originally Posted by RumpRangerSTX
new jersey home of thei love it
Quote:
Originally Posted by adsm08 View Post
My kids are gonna be able to count from 7 to 24 before they can walk.
"Kid, daddy needs the 13mm wrench."
wrecking-crew is offline   Reply With Quote
Old 02-06-2012, 01:09 PM   #5
Mrnicks
Junior Member
Vehicle Year: 99" Ranger 4.0L
I use this vehicle for: 99" Ranger 4.0L Straight pipes, K&N cold air, rear locker, 33"x12.5" bfg's and TSL's 3"body and 2"s
Mrnicks is on a distinguished road
Default
What was the conclusion to this? I have a similar problem.
Mrnicks is offline   Reply With Quote
Old 02-16-2012, 10:45 AM   #6
Mrnicks
Junior Member
Default
Try to bleed your steering system. That was my problem. With the truck running and the front end off the ground I turned the wheel almost lock to lock about twenty times. Most of the shake went away after that. Then after driving it for a few days it's all gone.
Hope this helps. Maybe it does maybe not. It really through me for a loop when I discovered to be my problem.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
