- Aug 7, 2007
- Age
- 64
- Blaine, Washington
- 4.0 V6
am getting ready to order the parts for my poor truck...but I am a bit confused. The shop that did the estimate didn't mention inner and outer tie rod ends...only *tie rod end*
On the LMCTruck site this pic shows the parts well in an exploded view...
http://www.lmctruck.com/pdfcatalogs/pdf/FR/0107.pdf
It looks Like I need to order Parts 1 through 6, we have the pitman arm already. Is that correct if I am replacing the whole steering linkage? (gods I must sound really stupid, but well...maybe I am )
And no I am probably not going to actually buy from, LMC, as I don't have enough money to spend without shopping around for the best value for the money.
I plan on replacing the left side as well, since she will be up in the air and torn apart. We also will be replacing the radius arm bushings while the truck is in the air.
Another thing I need to clarify is, I guess, should I also buy the adjusting sleeves new for the whole shebang? Or will my old ones work? Also, is it worthe putting the Steering Stabilizer Kit on? It isn't a lot of money if it really does what it says it does...
Gee can we tell who is a total NEWB to 4WDs?
