Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 02-17-2012, 12:27 AM   #97
chrwilkins30
chrwilkins30's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Used For: running over hondas
chrwilkins30 will become famous soon enough
Default
got the rest of my stereo parts installed. All alpine.
__________________
88 bronco II|3inBL|4in SJ lift|1354M|8.8/d35 w/4.56 R&P|M5od swap|Ex leaves|35 km2|classic Locks|Bushwacker Flares|JD tire carrier
Still NeedSliders|winch|snorkel|F250 towers|4.0
MY BUILD
WTBShifter Bezel like thishttp://i1090.photobucket.com/albums/...gershifter.jpg
chrwilkins30 is offline   Reply With Quote
Old 02-17-2012, 12:41 AM   #98
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
Will be ordering all my lift parts in probably 2 weeks. heres my list and prices.
James oak enterprises
Skyjacker Class II 4-inch suspension
Total:$1,232.95 USD
Summit
Pro Comp Suspension Systems 7315 - Pro Comp Brake Hose Kits
Skyjacker Suspensions FA600 - Skyjacker Pitman Arms
Skyjacker Suspensions H7058 - Skyjacker Hydro Shocks
Skyjacker Suspensions H7060 - Skyjacker Hydro Shocks
Belltech shackles
Part Subtotal $525.56
Bronco graveyard
Axle Pivot Bushings, (Pair) Red
OEM Lower Coil Spring Stud (2)
EachLower Coil Spring Stud Nut(2)
Total $67.66
Rock auto
Radius arm bushing
Total $36.02
GRAND TOTAL $1862.19
Will be running stock running gear for now since ill still be on 32's. Will swap to d35 and 8.8 when more money comes in for gears and other misc. parts. Plans are to get 35's eventually.
Anything Else I'm missing?
__________________
MY BUILD
Old 02-18-2012, 08:42 PM   #99
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
was out bending my sway bar back so the disconnects didn't have to be put on with tools. Heres a little flex with them disconnected.
__________________
MY BUILD
Old 02-29-2012, 11:27 AM   #100
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
Just ordered everything from summit.
Will order the lift in a little bit.
Decided im going to go get a d35 now, going next week during spring vacation.
__________________
MY BUILD
Old 03-01-2012, 02:34 PM   #101
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default Went to the JY
__________________
MY BUILD
Old 03-01-2012, 08:41 PM   #102
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
Got a question.
I looking to see what year this axle came from. ( forgot to look)
I did look on the door tag and It said 45 which is 3.55 R&P open.
How do I idenfity what year it is for parts with out using the axle tag. Its unreadable. I read in the tech library of it possibly being on one of the beams. Well none of my numbers matched up so here they are.
P 159 0 1
44066
Any Help!
__________________
MY BUILD
Old 03-01-2012, 08:57 PM   #103
Robert_1967
Robert_1967's Avatar
Year: 1988/1989
Make: Ford
Model: Ranger Supercab/BroncoII
Engine: 302/2.9
Class: 2wd Street/4x4 street
Used For: Soon to be hot rod/Daily Driver
Robert_1967 has a spectacular aura aboutRobert_1967 has a spectacular aura about
Default
The door tag should have told what year it was. too bad you didn't get it from "Pull-A-Parts", they mark all of their vehicles on what year they are, or at least the one in Knoxville, TN. does.
Robert
__________________
All Truths are Known upon Death.
If I can't work on my Ranger or BroncoII, I rather be fishing.
If Facebook, MySpace, and Twitter were all destroyed, 90% of teens would go insane.
Robert_1967 is offline   Reply With Quote
Old 03-01-2012, 09:04 PM   #104
kris97ranger
kris97ranger's Avatar
Year: 1997 2006
Make: ford
Model: ranger f 150
Engine: 4 litre and 4.2 litre
Class: 4x4 ranger 2wd f 150
Used For: ranger was rolled... working on rebuild. the f150 is for a dd and towing
kris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of light
Default
im glad our junkyards give out a printout of the year make model and vin for axles when i got mine. and gear ratios
__________________
97 ext cab 4x4 483'000km 33" duratracs 1" washer spacer "minor" fender trimming R.I.P
91 f350 cc/lb on 35s
88 lwb sammi toyota 22re on 38.5"s locked front/rear
97 reg cab ranger on 38.5s
kris97ranger is offline   Reply With Quote
Old 03-01-2012, 09:09 PM   #105
Robert_1967
Year: 1988/1989
Make: Ford
Engine: 302/2.9
Default
I should have added that the door tag will tell you the year IF they are the factory doors, my 88 Ranger has 86 doors on it, so I pulled what door tag it had off.
Robert
__________________
Old 03-01-2012, 09:15 PM   #106
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
I did pull it. Just didn't think to get the year. I was kind of in a rush went between classes.
Might just have to go back and look at the year
__________________
MY BUILD
Old 03-01-2012, 09:23 PM   #107
kris97ranger
Year: 1997 2006
Make: ford
Model: ranger f 150
Default
it should have a vin on it try running it through the vin decoder thats on here, should tell you what you want
__________________
Old 03-01-2012, 09:50 PM   #108
chrwilkins30
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4X4
Default
Also. Any one know if they make replacement brake dust shields?
I searched real quick and someone said that only 90-92 d35 came with dust shields. Any truth to this?
__________________
MY BUILD
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
