Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 10-07-2011, 03:39 PM   #1
kegs
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
kegs is on a distinguished road
Default 1989 Ford Ranger - replacing clutch need some help!
I'm working on a 1989 4x4 XLT Ford Ranger super cab that is fairly rusty (undercarriage has a lot of corrosion, though most of the bolts are o.k.)
The clutch is slipping really bad on it and it needs to be replaced. I figured I would do this myself. I am not new to working on automobiles, but it has been a long time since I messed with U joints, drive shafts, etc. I have never replaced a clutch on any vehicle before.
I read about switching out the 8" clutch to the 4 liter 10", but really don't want to do that as I'm on a tight budget and the extra parts would exceed it.
I would appreciate the help on some of the steps of this procedure.
I have a Haynes manual for this, but I seem to be missing details on how to remove the drive shafts.
What bolts are you guys taking off which drive shafts in order to get the transfer case out?
If you have a link to another thread to this, it maybe beneficial as well - I tried to use the search function, but no useful threads came up.
Thanks,
Kegs
kegs is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-07-2011, 07:32 PM   #2
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Remove the 4 bolts and 2 at the front pinion and then pull the front shaft out completely.
Then remove the 4 12-12 bolts at the front of the rear shaft and tie the shaft off to the frame with a bungie cord or something.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 10-07-2011, 08:31 PM   #3
chrwilkins30
chrwilkins30's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: running over hondas
chrwilkins30 will become famous soon enough
Default
if its a slip yoke front shaft you do not need to remove the front shaft at the pumpkin. also just remove the rear shaft at the axle this way you only have 4 bolts in total to remove( plus the transmission bolts possibly the tcase if your pulling it off and the trans crossmember.)
__________________
88 bronco II94 4.0|3inBL|4in SJ lift|1354M|8.8/d35 w/4.56 R&P|M5od swap|Ex leaves|35 km2|classic Locks|Bushwacker Flares|JD tire carrier
Still NeedSliders|winch|snorkel|F250 towers
MY BUILD
WTBShifter Bezel like thishttp://i1090.photobucket.com/albums/...gershifter.jpg
chrwilkins30 is offline   Reply With Quote
Old 10-08-2011, 08:50 AM   #4
kegs
Vehicle Year: 1989
Vehicle Make: Ford
Default
My biggest problem is that I am term ignorant. To me a pumpkin is a big orange thing in a garden.
I am going to post some pics of this rig, label the bolts and maybe someone can have a look at the pics to explain which bolts are which.
I have read the section in the manual about doing this and there are no pictures. I reefed on one of the 12 point bolts (1/2", but thinking these might possibly be metric sized) and I could not budge it.
Am I going to need an impact wrench to get these puppies off?
Based on torque specs, it doesn't seem like this would be necessary. I know I applied at least 100 ft/lbs. to these bolts and they would not move.
Old 10-08-2011, 09:41 AM   #5
gribly
gribly's Avatar
Vehicle Year: 2002
Vehicle Make: Honda
Vehicle Model: EP3 Civic Si
gribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of light
Default
Corrosion makes em stick hard. Get a can of pb blaster and spray the bolts, then wait for it to work in for a couple hours. They'll come out easier. Pumpkin is the rear diff.
__________________
"If at first you don't succeed, use more duct tape." - Uncle Red
"I can't feel anything, but I can't stand up!" - Tina
gribly is offline   Reply With Quote
Old 10-08-2011, 10:30 AM   #6
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
They are 12 mm, which is not quite as big as a 1/2 inch.
There should not be a single standard sized bolt head on your truck, it's all metric heads. As for the torque, a double wrench should get them off. You may need a poor man's impact (a wrench and a hammer).
The actual torque spec is irrelevant. Between the rust and the thread locker, they are on there much tighter than what they were tightened to.
As for gribly's idea of just spraying them with PB, just spray everything with PB and then come back to the job in 2 days. It will make everything easier.
Alternatively, you can drive through a pond of the stuff, if you can find it.
__________________
Old 10-08-2011, 10:37 AM   #7
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
on those 12pt bolts, it's not corrosion holding them in place it's the loctite, if you have a butane torch heat the flange side for about 30 seconds with that (less if you have a propane torch) and it will come out a LOT easier, also hitting the other end of the wrench with a hammer helps out...
For the front drive shaft you will need a torx bit where it goes into the axle, there are splines on the transfer case side so it will just slide out.
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
