Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-14-2011, 09:41 PM   #1
tjbushey
tjbushey is on a distinguished road
Default spark plug issue 4.0L ranger
Hello, i got a 2003 ford ranger xlt 4.0L and i did a spark plug change, got spark plugs from Ford Dealership AGSF34FP, says under my good 54" gap but the AGFS34FP is 65" gap what is the deal? did i need to gap the factory plug for the truck to the correct size?
Also i installed the plugs anyway, some reason there is now a ticking sound, so i replaced the wires thinking they might be broken after installing plugs but the ticking noise is still there and its pretty darn loud, also took them back out to make sure they were seated properly.
Thanks any help is great help at this time
tjbushey is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-14-2011, 09:55 PM   #2
06RangerXLT
06RangerXLT's Avatar
Vehicle Year: 2006
Vehicle Make: Ford
Vehicle Model: Ranger XLT Extended Cab
I use this vehicle for: Shenanigans
06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of
Default
yea set the gaps. the ticking is most likely preignition or "pinging"
__________________
Camburg BTF mid-travel kit, 64's, 33x12's,E-Fan Conversion, 4.56 8.8, McNeil Glass
06RangerXLT is offline   Reply With Quote
Old 10-15-2011, 12:20 AM   #3
Rolled Ranger
Rolled Ranger's Avatar
Vehicle Year: '91
Vehicle Make: Ford
Rolled Ranger will become famous soon enough
Default
Always set the gap. Most spark plugs do not come pre gapped. A little while back I saw the parts guy at work ask someone if he wanted his spark plugs pre gapped. After the guy said "Sure" he banged them on the counter a few times and said "There you go, gapped to zero. Always check the gap".
__________________
1991 Ranger 4x4, 4.0L, M5OD, 1354M
35" BFG M/T, 6" Skyjacker lift, 3" Body lift
Rolled Ranger is offline   Reply With Quote
Old 10-15-2011, 09:04 AM   #4
tjbushey
Default
thanks for the help guys, ill get right on gaping them, anyway how to get rid of the " pinging " when i 1st start the vehicle it doesnt do it untill its fully warmed up then i hear it , also someone said the spark plugs might be ungapable? how do i know if its ungapable?
Old 10-15-2011, 02:43 PM   #5
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Quote:
You know they are ungappable if you bought the shitty snake-oil multi tipped ones, or if they are a "bridged" design like the 5.4 uses.
Any Motorcraft plug for the 4.0 should be gappable. And you always have to set the gap because they get banged around during shipping and the electrodes move.
As for the noise are you sure they are all in tightly, no wires are crossed, and you don't have an exhaust leak?
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is online now   Reply With Quote
Old 10-15-2011, 04:18 PM   #6
tjbushey
Default
hey there, thanks for the tips, yea some of the wires are crossing each other but the stock ones were as well, im gonna take them out and gap them to the correct size.
Ill let you know a update
Old 10-15-2011, 05:30 PM   #7
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Not crossed as in crossing over each other. Crossed as in hooked up from the wrong coil terminal to the wrong plug.
__________________
Old 10-15-2011, 06:43 PM   #8
tjbushey
Default
oh i see, no shouldn't be, i did 1 wire at a time to make sure i didnt get them mixed up. Ill double check everything tomorrow and after i Gap them, and ill try to pinpoint where the ticking is coming from.
also truck feels like it has less power and sluggish but probaly has to do with the gap.
Ill put updates tomorrow
Thanks again
Old 10-15-2011, 09:31 PM   #9
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
That's a good practice, but believe it or not, I've seen wires get mixed up even with that.
If it's not missing at all then you should be ok. Get your plug gaps set right at see how that works. Try to get them as close to the low end of the range as you can since the gap will open up a bit as they wear.
__________________
Old 10-16-2011, 09:41 AM   #10
tjbushey
Default
will do! ill find a firing order chart to and double check the wires
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
