Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Suspension & Armor > Fabrication
Fabrication Bumpers, sliders, cages, flatbeds, tube work, etc.
Reply
Thread Tools Display Modes
Old 10-21-2011, 08:42 PM   #1
Airmaster
Airmaster's Avatar
Vehicle Year: 2006, 2013
Vehicle Make: Mazda, Chevy
Vehicle Model: B3000, Camaro
I use this vehicle for: Reminiscing... RIP B3000
Airmaster is on a distinguished road
Default Whats involved in front fender removal?
Hey guys, I'm wanting to beat out a dent I have on my left front fender and it seems the only way to get behind it is to remove the fender.
What exactly is involved in taking the fender off, it looks like a lot of stuff is attached to it :/
Will it be possible to beat out the dent or will I have to be looking at getting a new fender?
Here's a picture of the dent...
It's not too bad and at certain angles its almost hard to spot, but its annoying none the less. My new rims are coming and I want the truck looking good for its new pair of shoes.
Airmaster is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-21-2011, 08:44 PM   #2
whale
whale's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Winter Ride / Beater Truck
whale will become famous soon enough
Default
What if you used a dent puller? You know, it welds a little stick onto the metal, and you use a slide hammer to get it out.
Will
whale is offline   Reply With Quote
Old 10-21-2011, 08:54 PM   #3
Airmaster
Airmaster's Avatar
Default
I'll have to look into that but I think a friend of mine told me those things are worthless, thats why I havent wasted time trying to track one down
Old 10-21-2011, 08:57 PM   #4
CHKNFKR
CHKNFKR's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Spending my hard earned cash
CHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant future
Default
There are four bolts on the top, two behind the turn signal, one under the turn signal, one on the bottom directly in front of the door and one on top that you have to open the door to get to. I think they're actually 8mm but 5/16" fits just as well.
__________________
Quote:
Originally Posted by daniel3507 View Post
This pick up makes my pecker perk up
Quote:
Originally Posted by gwaii View Post
all my layout,bend allowances,and cuts are figured out using a neural cognitive software system.
Quote:
Originally Posted by super91(2.3) View Post
I can see myself goin to the gas station now and buying under a dollars worth of diesel and just dispensing it right onto my body...
CHKNFKR is offline   Reply With Quote
Old 10-21-2011, 09:00 PM   #5
CHKNFKR
CHKNFKR's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
And thre isnt anything attached to it. The battery tray, fuse box, etc, are all attached to the inner fender. The panel you want is bolted to that.
__________________
Old 10-21-2011, 09:02 PM   #6
whale
whale's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
Default
Quote:
It easily pulled a dent out of my Triumph tank. Guess that's different than a fender...
Will
Old 10-21-2011, 09:07 PM   #7
3.0ranger1227
3.0ranger1227's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: DD, playing in the sand
3.0ranger1227 will become famous soon enough3.0ranger1227 will become famous soon enough
Default
I want to say it's a weird size, maybe 7mm? also be careful two of the bolts hold the main distribution box on.
__________________
2003 Edge 2WD 3.0, Camburg Performance 6.0 dual shock, SSBC rear disc brakes
Red Stepside
4.3L on the way!
3.0ranger1227 is offline   Reply With Quote
Old 10-21-2011, 09:10 PM   #8
CHKNFKR
CHKNFKR's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Quote:
You dont have to touch that. Its attached to the inner fender. The only thing you have to remove to remove the fender is a headlight assembly. And its not even attached to the fender, it just covers up the two bolts you need to get at.
__________________
Old 10-22-2011, 05:00 PM   #9
straycat
straycat's Avatar
Vehicle Year: 02 06 and 2012
Vehicle Make: Jeeps
Vehicle Model: 02 Grand Cherokee 4x4 4.0L 06 Wrangler X 5.7 Hemi 87 Samurai 4x4 2012 Wrangler JK-8
I use this vehicle for: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
My buddy had a dent just a bit bigger than yours on his F150 near the bumper area, too. He called Dent Master and a guy came to the house and popped it out for him. It was about $70.00 for the call. My buddy told me that was worth it. He was going to take off the front fender and he said that was time consuming to him. It did not need any paint repair. Dent Master can do paint repair as well on a call.
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Old 10-22-2011, 07:27 PM   #10
gwaii
2010 OTOTY Winner
gwaii's Avatar
Vehicle Year: 1991
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: stupid stuff
gwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to beholdgwaii is a splendid one to behold
Default
while there is some good info on removing the fender,and even options for taking care of the dent.....
it still begs the question.....................
WHAT THE HELL IS THIS THREAD DOING IN THE 'FABRICATION' SUBFORUM?
thank you.[/rant]
__________________
just the facts,ma,am-joe friday
gwaii is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
