Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-22-2011, 07:08 PM   #1
88fordman
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT
88fordman is on a distinguished road
Default 2.3L to 2.8L stroker kit
so my 2.3L 88 ford ranger recently blew it's head gasket, i'm going to strip the engine bare and resurface the block and heads. this will be a weekends projects with my dad. now that i make decent money i'm thinking on updating the beast.
what i'm looking for is more torque and horsepower in low low rpms, were talking about idle to a max of 3000 rpms. i dont plan on racing the truck nor do i even take it above 2,500 rpms. i want really low rpm torque, its pretty hilly where i live and want that down low power so i dont have to rev the engine high or switch to a lower gear
i think race engineering sells a stroker kit that would take the 2.3L to a 2.8L
http://www.raceeng.com/p-13002-rotat...crank-kit.aspx i say i think they sell it because i dont know if this is what this kit is for, meaning i dont know if this kit is to stroke the 2.3 to a 2.8
i would greatly apprciate it if you experts on here could answer a few of my questions.
with this kit would i have to trim anything for the new enternals to fit or should it be more or less a drop in kit.
roughly how much more power and torque would this add, since power numbers very on so many variables, maybe what kinda of percentage of power could i expect.
would this kit be realiable, sorry i'm a total noob when it comes to this stuff but would this kit decrease the engine life, assuming my block and heads are it tip top shape. i've heard that these kits are actually stonger than stock, but also i will be running more compression.
would i need to drop in a new cam to compensate for the higher compression ratio, i already plan on adding an adjustable cam timing gear.
is there another kit that would take it this new size for cheaper or is ther one thats better
i know that it would probably be cheaper to drop in a turbo motor or something like that, and i know i'm going to have to replace many parts which will cost time and money, but the thing is is that my father brought this truck new in 88 and its been in the family since, in fact he gave it to me as my first vehicle. i have so many great momories in this thing that its priceless. and i want to keep it more or less orginal, i know parts have been replaced but to replace its entire engine (whole engine block and everything else) seems like it would be taking something away from it, that it would no longer be orginal. but updating its parts seems more like a gift to the vehicle for all its hard work, realiablity and service over the past years.
88fordman is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-22-2011, 07:18 PM   #2
88ranger89camaro
88ranger89camaro's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Hay Hauler, Drive to Work Truck
88ranger89camaro is on a distinguished road
Default
its increasing the stroke of the piston, i know in a SBC (small block chevy) you have to notch the block to clearance the end caps on the connecting rod.
Doing that, a better cam and some head work would really wake the 2.3 up, but then again the turbo would to, i would think with you wanting low end power you could really benifit from the cam swap and head work
dont quote me on all this when it comes to making more H.P. i stick to my
V8's
88ranger89camaro is offline   Reply With Quote
Old 11-22-2011, 07:24 PM   #3
Gotta_gofast
Gotta_gofast's Avatar
Vehicle Year: 2006
Vehicle Make: Ford
Vehicle Model: F250 FX4
I use this vehicle for: Droppin panties
Gotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to all
Default
2500 dollars!?! I wouldn't waste my time. Hell I could buy a V8 doner explorer for that.
In 88, I think those 2.3s were rated under 100 horsepower. With that stroker kit you might bump up to 120ish but that is very optimistic! With the cost of the stroker kit, the block machining for the kit, and all the other parts needed to make it worth your while it would be way cheaper to swap in a 2.3 turbo motor or even a V8.
__________________
2006 F250 Super Duty Fx4. 6.0L powerstroke ARP studs, EGR delete, 4" turbo-back, bullydog intake, SCT livewire TS with looney tunes...
(sold) SUPERCHARGED 2005 Ford Ranger
Gotta_gofast is offline   Reply With Quote
Old 11-22-2011, 08:25 PM   #4
88ranger89camaro
Vehicle Year: 1994
Vehicle Make: Ford
Default
Quote:
Originally Posted by Gotta_gofast View Post
2500 dollars!?!
i didnt see that THAT!!!!!!!!!!!!!!!!!!!!
yeah um he could do ALOT to his 2.3 for that price and have more power than that stroker kit ...... I got a friend with a pinto with a 2.3 with only head work, a cam, intake, and headers and it screams for what it is, not near a fast as his 351 pinto but still dang good for a 2.3
Old 11-23-2011, 12:30 PM   #5
DJ2.3
Junior Member
DJ2.3's Avatar
Vehicle Year: 83/92/94
Vehicle Make: Ranger
Vehicle Model: 2wd
I use this vehicle for: anger management
DJ2.3 is on a distinguished road
Default
If money isn't an issue go for it. but if i was you i would swap in 2.5 internals and spend the 2500 on an aluminum head. Assuming you are FI, if you stroke it to a 2.8 or run serious cam/compression you will likely need some sort of tuning.
DJ2.3 is offline   Reply With Quote
Old 11-23-2011, 01:09 PM   #6
pinturbo75
pinturbo75's Avatar
Vehicle Year: 1992
Vehicle Make: ranger
Vehicle Model: xlt
I use this vehicle for: work truck
pinturbo75 is on a distinguished road
Default
also, your 88 block is a large main journal.... to use your block youd need 2.5 main caps and spacers and have it line bored or start with a newer 2.3 or 2.5 small main journal block...
__________________
92 ranger 2.3 5sp... soon to be turbo
75 pinto turbo
pinturbo75 is offline   Reply With Quote
Old 11-23-2011, 01:55 PM   #7
ES894x4
December 2013 STOTM
Vehicle Make: Ford
ES894x4 is on a distinguished road
Default
nothing is going to give you the v8 torque like you want. NA its still a sohc 4cyl and stroking it isnt going to do much maybe 10-15ftlbs your going to hit the tq wall where you can keep upping the horsepower to 200+ but the tq will flatline somewhere around 150ftlbs no matter what you do NA. shifting below 3k should be cruel and unusual punishment on a 4cyl, no 4cyl is going to cruise up a mountain in 5th gear, down shifting and revs are apart of the game.
__________________
Chances are if you are too lazy and incompitent to do some basic research, you'll be too lazy and incompitent to successfuly work on a vehicle.
ES894x4 is offline   Reply With Quote
Old 11-23-2011, 09:32 PM   #8
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
Quote:
This.
Lugging an engine is usually a lot worse for it than revving it.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 11-23-2011, 10:01 PM   #9
Mutant Pony
Mutant Pony's Avatar
Vehicle Year: 1977
Vehicle Make: Ford
Vehicle Model: Pinto
I use this vehicle for: Mud racing/trails
Mutant Pony will become famous soon enough
Default
The 2300 ford motor comes to life at 3000 rpms. It will run all day long between 3000 and 6000 rpm. Lugging down below 3000 will just take the bottom end out quickly! If you want to stay under 3000, the only engine that will work is a V8. A 4.0 ohv would work but, it would be right on the edge ALL the time. Never gonna happen with 2.3 based engine.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 11-24-2011, 06:54 AM   #10
4b316
Vehicle Year: 1995
Vehicle Make: ford
Vehicle Model: ranger
4b316 is on a distinguished road
Default
Agree with all the above,if you want the torque,go to the V8 mod.If you want a good little pulling motor,get a 90-94 engine and put in a 2.5 crank,pistons and rods.Get a stage one roller cam,bore 40 over,wack the head 60,do the above mentioned port and polish on the head,24 lb injectors and run a good header.Should be able to put together a decent motor for under $1500,i have about the same in mine and we have about $900 in it but we had the two motors.Buy a 302 for $2-$300,get a kit and drop it in,takes about 50 hours to swap if you have the pieces
4b316 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
