Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-13-2011, 10:52 AM   #1
Dogface
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT 2WD
Dogface is on a distinguished road
Default 97 Ranger 2.3L Misfire when cold
The problem I`m having is, the thing starts up right away idles perfectly, then I start down the road go 1000ft or 1500ft to a stop and it starts to miss and shake and has no power. It will do this untill it is at full operating temp then it runs fine and idles like a singer sewing machine. I have ohmed out the temp sensor and the values change as the temp changes, other things have been replaced just not the temp sensor.
Can the temp sensor be faulty midway and will that make it misfire and send
a code? I have not had a Temp sensor code yet just the misfire. I plan to replace the sensor but thought I would see if anyone has had this problem before, Any ideas!
Thanks
Dogface is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-17-2011, 09:42 AM   #2
Autto27
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger xlt
I use this vehicle for: Daily Driver
Autto27 is on a distinguished road
Default
the ECT? engine coolant tempurature sensor? no that wouldnt cause a rough idle. it only measures the tempuature of the coolant and sends information back to the pcm which in turn adjust your long and short term fuel trim to match the engine tempuature for best running conditions. my guess would be wires or dis packs. run your engine at about two grand and lightly mist water over the wires, if you see little sparks mid air it means the wires are bad, this can be caused from buying cheep wires or not changing wires. it could also be plugs, check your ignition system, 90% of the time misfires are and ignition issue.
Autto27 is offline   Reply With Quote
Old 12-17-2011, 12:30 PM   #3
Autto27
Vehicle Year: 1995
Vehicle Make: Ford
Default
your EGR may be sticking when the engine is cold, then as it warms up it will float freely, that would explain the feeling of a miss and a rough idle, you dont want the EGR opperating at idle. it screws with the Stoichiometric Ratio
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
