Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 01-18-2012, 02:55 AM   #1
JSL
Vehicle Year: 1999
Vehicle Make: Ranger
Vehicle Model: XLT
JSL is on a distinguished road
Unhappy Transmission Fluid Change and now?...won't shift gears! HELP
1999 Ford Ranger XLT, V6 3.0L Automatic - I performed a transmission fluid change today and when starting vehicle to back off ramps the truck would not shift into reverse or any other gear. What could I have done wrong when removing pan and old filter, then replacing with new filter and bolting pan back on? I have not put any fluid in yet. I reset PCM by removing negative post connector for 20 minutes on battery, nothing. Please help! Thanks, Jennier
JSL is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-18-2012, 03:09 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
Seriously?
No fluid in an automatic transmission means it will not move. Stop trying to drive it without fluid in it, you will burn it up.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 01-18-2012, 09:01 AM   #3
kryptonitecb
kryptonitecb's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: daily driver, trail ready
kryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nice
Default
You probably already burned something up just by trying to move it.
Sent from the road while ignoring traffic
kryptonitecb is offline   Reply With Quote
Old 01-18-2012, 09:07 AM   #4
LIMA BEAN
LIMA BEAN's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger SXY
I use this vehicle for: Doing dirty deed's dirt cheap.
LIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond repute
Default
OUCH, How did you check fluid level while unlevel on ramps, is there an APP for that?
__________________
88 Ranger
http://www.cardomain.com/ride/2459246
"You have come to take our evil black guns? heh heh be right with ya there mister."
LIMA BEAN is offline   Reply With Quote
Old 01-18-2012, 09:59 AM   #5
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
Add atf until it reaches just above the full mark then start it set the ebrake and shift into neutral then check it again running in neutral. You dont want to overfill and as the tranny warms up the fluid will expand so keep it just below full for a bit then take it for a road trip. after about half hour of running it check that the level is full once again running in neutral. I dont imagine you hurt anything unless you run the engine at high rpms or got it too hot running without oil for too long. All you can do is add oil and hope for the best. GL
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 01-18-2012, 10:08 AM   #6
LIMA BEAN
LIMA BEAN's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
Quote:
Yep what he said^^^^ and lets hope for the best.
__________________
88 Ranger
Old 01-18-2012, 10:09 AM   #7
RatDog8o8
RatDog8o8's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger Custom
I use this vehicle for: Vehicular things
RatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond reputeRatDog8o8 has a reputation beyond repute
Send a message via AIM to RatDog8o8 Send a message via Yahoo to RatDog8o8
Default
Quote:
That's what you "did wrong"....the statement in red.
The fluid in an auto trans is what makes the parts inside do what they do. It's called "hydraulic pressure".
__________________
Doin' what I do at the mind-numbing speed of 352 fpm!
RatDog8o8 is offline   Reply With Quote
Old 01-18-2012, 12:17 PM   #8
jhammel85
Lurker
Posts: n/a
Default
Why would you move it without fluid?
Fill it up and hope for the best...I really hope that you didn't burn it up.
Old 01-18-2012, 06:11 PM   #9
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
I've backed mine off of ramps after draining the fluid from my stickshift just to get it in a better position for refilling it. Maybe that's what the OP was trying to do? (just giving the benefit of the doubt here)
As has been said, that doesn't work so well with an automatic.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 01-21-2012, 01:33 AM   #10
kryptonitecb
Vehicle Year: 1994
Vehicle Make: Ford
Default
Manuals are a completely different animal. Still you shouldn't run either without fluid ever ever ever ever!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
