- Dec 14, 2008
- Reaction score
- 79
- Location
- Mich
- Make / Model
- ford
- Engine Size
- 2.3turbo
*copied and moved from General area*
I have a 88 longbed with 42k miles that I picked up 4 years ago to build into an all out drag radial racer and even built a 410w and a 75mm turbo. Well the motor never made it into the truck and now I wana use the truck for daily driving so Im going back to my roots and dropping a nice 2.3t in it.
The motor is a fresh stock shortblock, worked over head with custom roller cam,Bobs intakes and header,custom .70/.63 turbo by Evergreen,LA3,35lb injectors {for now},Centerforce II clutch,TC t5 and a NPR front mount. I will upgrade to Stingers PIMP setup at a later date.
I have a drum brake 8.8 out of an Explorer and I want to use it with a Aubrun Pro I have with the stock 3.55's. Will be doing a shackle flip as well for the 2" drop.
I have a set of 90 Lincoln LSC 16" wheels with 225's on them that will be getting some powdercoating done.
Truck will be getting fresh white paint after its running and it already has a glass 2" hood. Truck has zero rust other than where factory paint has flaked off and the bare metal was exposed.Nothing more than surface rust you can wipe off with a finger.I will be replacing all bumpers,trim,grill and seals with new stuff from LMC. Im keeping all the chrome also. Gona be Oxford White with the top of hood done in black with lots of new chrome...I want it to shine like a piece jewelry!
For the interior I really want to do something special. Im changing the factory blue to either grey or black or maybe a combo of both. I have a set of leather SVO seats I would love to use.I already had a 2.3t 87 Ranger with a t5 and bench which made for some really crappy shifter handles...buckets it is this time. I plan to use Speedhuts Revolution GPS speedo and tach in my own dash cluster,Siruis radio and I want to try to swap in a newer Ranger column with tilt and a nicer steeringwheel if possible....is it?
On to the "before" pix!
![](http://i681.photobucket.com/albums/vv173/deathbypsi/ranger/2009_0509ranger0001.jpg)
![](http://i681.photobucket.com/albums/vv173/deathbypsi/ranger/2009_0509ranger0003.jpg)
![](http://i681.photobucket.com/albums/vv173/deathbypsi/ranger/2009_0425dragranger0016.jpg)
![](http://i681.photobucket.com/albums/vv173/deathbypsi/ranger/2009_0425dragranger0009.jpg)
![](http://i681.photobucket.com/albums/vv173/deathbypsi/ranger/2009_0425dragranger0022.jpg)
