Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-11-2012, 04:39 PM   #1
dschmitt5.0
dschmitt5.0's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4x4
dschmitt5.0 is on a distinguished road
Default Driveshaft Vibrations
Hey all,
I was looking for alitttle bit of gudiance on this issue. Acouple weeks ago i narrowed my problem down. My driveshaft has internal splines on on the back end of the shaft. Then there is a short piece with external splines that is connected to the rear pig by ujoints and four 12mm bolts. The splines our worn and there is def some slack between internal/external splines. I took this apart and greased the hell out of the internal splines with some super heavy grease. The grease was like tar. I put it back together and it seemed to work for about 3000 miles. The vibrations went away. Now its back and is driving me nuts. The vibration is only there when u push the clutch in to coast or lift off the gas while on the highway. My question is, do they make a single solid shaft for for a 1994 ford ranger 2.3 4x4 single cab 5 speed. If so where can i find one. Thanks for all your help in advance.
__________________
" There's 2 kinds of problems. My problem and not my problem. If it is my problem try to make it someone elses problem":
----KEEP IT SIMPLE STUPID----
dschmitt5.0 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
