Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Ford Bronco II's
Ford Bronco II's Be sure to check out the Bronco II Corral!
Reply
Thread Tools Display Modes
Old 02-27-2012, 08:37 AM   #1
K_Lynn
K_Lynn's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Explorer XLT
I use this vehicle for: Daily driver
K_Lynn is on a distinguished road
Default 1996 Ford Explorer XLT-work in progress
1996 Ford Explorer XLT 4.0 OHV, Auto, 4x4
Just bought on February 23, 2012. It was stuck in 4-low, so we swapped and installed a manual transfer case. It was starting and ran in first gear, but we reused original hardware on the filter by accident. So we dropped the transmission pan again (hoping the only issues was air). Now it doesn't want to shift at all. It starts fine but struggles to drive and gets up to 3000-4000 RPM, then I have to let off the gas for it to wined down.
Second day of having it home and in total we changed- air filter, transfer case, transmission fluid & filter, wiper blades, spark plugs, oil change & filter.
Here's a look under my hood.
Right now I just want to get it running! I'm just learning how to do more than filters, checking the oil, and filling tires. My boyfriend (disciplerocks) is use to working on manuals, so automatics is a lil' different for him. My speedometer and odometer don't work either. It is computerized, D (boyfriend- disciplerocks) thought the '96 models weren't, so it's not as easy as a fix as we had hoped. Once it gets running and the important things are working, my list is as follows: coolant, get it detailed, get steps added on, new steering wheel, change cassette player out with a CD player, see what's wrong with the AC, get a new antenna...I'm sure the list will continue, as does the list D's B2 and Focus
Here's a look on the inside, and you'll understand why I want it detailed.
The 15 inch tires are alright. The steering wheel needs replaced, I threw a steering wheel cover on it for now.
Here's a thread D put up, he explains what's going on with it a lil' better.
http://therangerstation.com/forums/s...d.php?t=123304
I'm ready to get dirty and get it running, so any suggestions will be welcomed.
__________________
Quote:
Originally Posted by disciplerocks View Post
Finally going to make me a thread. Not going to go crazy.
K_Lynn is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-27-2012, 08:46 AM   #2
railman
December 2011 OTOTM Winner
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger SC 4X4
I use this vehicle for: everything
railman will become famous soon enoughrailman will become famous soon enough
Default
only thing I can think of is straighten out the cover on the wheel.....it's not lined up right
as for the tranny, did ya run the gear selector through all the gears before ya tried to move it....right after the fluid change???
l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches......
railman is offline   Reply With Quote
Old 02-27-2012, 08:55 AM   #3
K_Lynn
K_Lynn's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Default
I don't care about the wheel cover. LOL. I did a run through of the gears after the 2nd fluid change. I didn't quite hit each gear one by one...I tried. I went through it 2x's. I told D to fill it with gas and try to drive it again before messing with it again. He had to drain fluid after our 2nd time bc/ after driving it up the road and back the dip stick said it was too full...having trouble getting it just right.
__________________
Old 02-27-2012, 09:30 AM   #4
disciplerocks
July 2011 OTOTM Winner
disciplerocks's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: the rippin and the tearin
disciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to behold
Default
In on page one!
Future plans include 5r55e swap, dana 30, 4:10s, locked, and 33s.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA
94 F150 XLT: 5.0 HO, OBDII, E4OD
04 Focus ZX3: Built 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s
12 Focus SE: Sport & Winter Package, ST Front End
Quote:
Originally Posted by AllanD View Post
Ford says (about towing not masterbation) "Don't do that!"
disciplerocks is offline   Reply With Quote
Old 02-27-2012, 09:33 AM   #5
disciplerocks
Vehicle Year: 1989
Vehicle Make: Ford
Default
Hopefully get to look at it Tues. Going to pull codes, reset ecu, check all plugs and vacuum lines.
__________________
Old 02-27-2012, 08:33 PM   #6
K_Lynn
K_Lynn's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Default
33's are NOT going on my truck, sir.
__________________
Old 02-27-2012, 08:37 PM   #7
disciplerocks
Vehicle Year: 1989
Vehicle Make: Ford
Default
Eventually....
__________________
Old 02-28-2012, 07:20 PM   #8
disciplerocks
Vehicle Year: 1989
Vehicle Make: Ford
Default
Ok so I replaced the solenoid that threw the code and it still wouldn't shift. Next thing to check was the intermediate band. Tried the adjustment screw, and sure enough it went all the way in. Weird I didn't see anything in the pan.
__________________
Old 02-28-2012, 08:18 PM   #9
getrdone52
Premium Member
getrdone52's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: Daily Driver
getrdone52 is a splendid one to beholdgetrdone52 is a splendid one to beholdgetrdone52 is a splendid one to beholdgetrdone52 is a splendid one to beholdgetrdone52 is a splendid one to beholdgetrdone52 is a splendid one to behold
Default
In on page one!
Quote:
Lol. I wonder how much of this build is going to be this. Hopefully you get it running soon.
__________________
BUILD THREAD
Quote:
Originally Posted by 88_Eddie View Post
woah, woah, woah, buddy....are you trying to give the man bad advice? you never, under any circumstances, put a doodad on a doohicky. it'll cause the thing-a-ma-jig to vibrate too much and wear out the whatchamacallit
getrdone52 is offline   Reply With Quote
Old 02-28-2012, 08:26 PM   #10
86 slo-vo
02/2011 OTOTM Winner
86 slo-vo's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: work and play
86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all
Default
You messed up Dustin, I keep my wife out of here so she can't figure out my plans.....for her truck or mine
__________________
FORD....built without your tax dollars.
86 slo-vo is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
