| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Extreme Suspensions Non bolt-on suspension swaps. 3 & 4 links, eliptical, and other custom suspensions. Forum sponsored by Ruff Stuff Specialties |
Thread Tools | Display Modes |
#13 |
MALL CRAWLER POST WHORE!
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (4)
and leafs set up right, will ride just fine, and flex just fine... you just gotta use the right leafs.
Tweet
#14 |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
Used For: trails/daily driver
Rep Power: 7 ![]() iTrader: (0)
Got any pics of said Geo Tracker?
They will flex fine they will not give amazing flex like coils and coil overs do.
__________________
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60U, 38.5" TSL SX's, build thread |
Tweet
#15 | |
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
Rep Power: 26 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (5)
Quote:
I helped do a leaf spring build on a YJ a few years ago, it got a surprising amount of flex (took a little experimenting with spring packs to get it right, but it comes with the territory). We ended up doing a 3/4 elliptical in the rear while we were at it. It actually flexed better than my choptop that is running coils up front and leafs out the back. That said.... for the OP, I would lean towards using coils or coilover/air shocks simply because the axle is most likely set up for coils and if you decided to go with something different, why convert the axle to leaf springs....
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd "S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4 1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's "Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy) 1989 Ranger parts donor: 4cyl, manual trans, 4x4 |
Tweet
#17 | |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
Quote:
To go to coil overs would take just as much fab work as leafs. Going with a stock diameter coil is were the time saving/money savings is.
__________________
Tweet
#18 | |
December 2011 OTOTM Winner
Year: 1996
Make: Ford
Model: Ranger SC 4X4
Engine: 4.0
Class: 4x4 Extreme
Used For: everything
Rep Power: 15 ![]() ![]() iTrader: (2)
Quote:
considering he has a 98+ IFS truck.....any SAS is gonna be alot of fab work....but in this case leaves would be easier.... plus, he never mentioned he was goin for a buggy anyways.... l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches...... |
Tweet
#19 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
Sounds to me that you need to post them pictures to see if maybe it is a Dana 30 and not a 44.
__________________
HE WHO DIES WITH THE MOST TOYS WINS |
Tweet
#20 | |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
Quote:
![]() Depends pretty easy to check if its 5 on 4.5" its a D30. 5 on 5" can be as well but they are a little more rare and just as strong as an EB D44.
__________________
Tweet
#21 | |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
__________________
Tweet
#22 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
If it is a Dana 30 from an early bronco it will be 5 on 5.5 not the 5 on 4.5.
__________________
Tweet
#23 |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
I thought the Bronco was a D27 or 28 not a 30? The D30 I was referring to in my post was a JK D30 with 5-760x joints and the bigger ujoints.
__________________
Tweet
#24 |
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
the jk dana30 is not as strong as the eb44 in stock form.. but the aftermarket support for them is HUGE. the jk dana30 is a slightly glorified d30, period.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
