Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-06-2012, 04:28 AM   #1
An Audio Guru
Junior Member
An Audio Guru's Avatar
Year: 92
Make: Ford
Model: Ranger
Engine: 3.0 v6
Class: 2WD
Used For: Daily Driver, play, work
An Audio Guru is on a distinguished road
Default Ebrake and rear abs light flickering randomly when driving or braking
I can't figure this out. When I am driving...usually during acceleration or braking the ebrake light will flicker on and off and occasionally the abs will flicker on and off too. Recently put a new rear end in and rebuilt drums and replaced ebrake pedal and cables. Don't know if this is helpful but maybe someone can direct me to a sensor or a trigger that is being tripped. Maybe the ebrake is not full releasing but how do I check this? Any help appreciated. Thanks!
__________________
Got Danger Ranger Fever again....
An Audio Guru is offline   Reply With Quote
Old 04-06-2012, 06:16 PM   #2
tx3nc
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0L V6
Class: 2WD Street
tx3nc is on a distinguished road
Default
The "E-brake" light is also your 'brake fluid low' light. Check your master cylinder is full.
If that is ok, then check the 3 wire plug (it might be 4 wires, I can't look at mine now) that goes into the bottom of the plastic master cylinder reservoir. If that connector is corroded or the wires going into the connector are corroded it can cause the level sensor to malfunction. If the 'BRAKE" warning light is on, the RABS is disabled. That is likely why the ABS light is coming on.
tx3nc is offline   Reply With Quote
Old 04-08-2012, 03:44 AM   #3
An Audio Guru
Junior Member
Year: 92
Make: Ford
Model: Ranger
Engine: 3.0 v6
Class: 2WD
Default
Thank you. Will check it out!!
__________________
Old 04-08-2012, 10:14 PM   #4
An Audio Guru
Junior Member
Year: 92
Make: Ford
Model: Ranger
Engine: 3.0 v6
Class: 2WD
Default
Looks like maybe a mix of that and I am thinking that maybe the cable itself is a tad too tight and therefore switch tripping bc when I play with the pull and ride with it pulled the light doesn't comes on at all. So how to loosen the cable(release some tension)? The reservoir was not all the way at "MAX" btw and it had been topped off Tuesday. Topped it off again and haven't seen the rear abs light at all. Pig tail looks fine but didn't have a second set of eyes for while I was playing with the tail.
__________________
Old 04-10-2012, 10:34 AM   #5
tx3nc
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0L V6
Class: 2WD Street
Default
I'm not sure how to adjust tension in the parking brake cables.
Old 04-10-2012, 02:39 PM   #6
kryptonitecb
Premium Member
kryptonitecb's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: daily driver, trail ready
kryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nice
Default
What year and axle do you have?
Sent from road while ignoring traffic
kryptonitecb is offline   Reply With Quote
Old 04-11-2012, 11:31 PM   #7
An Audio Guru
Junior Member
Year: 92
Make: Ford
Model: Ranger
Engine: 3.0 v6
Class: 2WD
Default
Honestly I have no idea. I do know that it is different from the original that was in there. I think I also heard someone mention that it looks like a rear end from an older model ranger. i payed a shop to slap it in. I'm not allowed to do that type of work at the apt complex.
__________________
Old 04-12-2012, 07:47 AM   #8
kryptonitecb
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
Ok, I'm not certain how to adjust the parking brake on all the different models. If you do a search you should be able to find how to do it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
