Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-07-2008, 12:27 AM   #1
Hardwareman
Hardwareman's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
Hardwareman is on a distinguished road
Default How to tell if a fuel pressure regulator is bad?
Hey guys, I just replaced and repaired my engine and swapped out my transmission at the same time for a newer one. I have a problem however. Before I pulled the motor it idled kind of wacky, like up and down on the rpm's. I thought it was a tune-up issue because I had'nt changed the plugs and wires in a while but after I got the whole engine cleaned up with new gaskets and seals and then tuned it up and put it back in, it's doing the same thing.............rpm's kind of up then down. Erratic!
It's not like the IAC valve, it's more like it lopes and idles erratically. I feel no blow by at the exhaust either. The PVC valve is new, the air filter is good, and as far as I know the head gasket does'nt appear to be leaking from what I have seen. The fuel pump and fuel filter is also new. The only other things I can think of is the fuel pressure regulator or worn camshaft lobes, which I hope it is'nt. The engine does have over 200,000 miles on it but I've had it for the last 150,000 or so of those miles and have regularly maintained it.
I know these engines can go for a long time if taken care of and not abused but I'm totally stumped here guys. Now that I've taken care of all the leaks this engine had can someone point me on where to look? Thanks.
EDIT: By the way, it only does this at idle. After idle it's fine.
Allen
__________________
1995 Ranger Extra Cab
2.5 Swap
8.8" w/4.56's and Posi
31" Rubber (Remington Right Now)
Thrush Turbo Muffler
4" RC Lift w/6" SJ Coils
Overbuilt's better then underbuilt. After a 12 pack of beer and a dare from your best friend.
Hardwareman is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-07-2008, 09:27 AM   #2
zamos
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
zamos is on a distinguished road
Default
A surging idle is generally caused by either the IAC ( may need to be reset ) or un-metered air is entering the engine - maybe a vacuum leak or intake gasket
zamos is offline   Reply With Quote
Old 03-07-2008, 12:23 PM   #3
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Vehicle Year: 2009
Vehicle Make: Chevy
Vehicle Model: 2500HD
I use this vehicle for: Shaming Sports Cars
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
If you pull the vacuum line off the FPR, it will usually have raw fuel in it if bad.
It does not always do this, but most of the time it will.
However, the FPR will usually make it hard to start once it's been run.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Old 03-07-2008, 01:57 PM   #4
Hardwareman
Vehicle Year: 1995
Vehicle Make: Ford
Default
Ok, that's not it I think?
The idle problem continues. I think maybe I'll do a fuel pressure and/or compression test/check.
Allen
__________________
2.5 Swap
Old 03-07-2008, 03:49 PM   #5
TireIron
RBV Technical Advisor
TireIron's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
TireIron is on a distinguished road
Send a message via AIM to TireIron
Default
do you have a vacuum gauge to check the vacuum the engine is pulling? if youre below 18-20 then you have a vacuum leak somewhere...
__________________
'94 2.3L, M5OD, BW1354 manual, 4x4, 31x10.5 BFG A/Ts, 15x8 AR Chamber teflon rims, 7.5 4.10 lock-right w/disks, D44 SAS 4.10 aussie-locker, duff traction bars, electric fans, spintech muffler, herculined floor, 400,600 miles
My Truck
Wheelin Pics!!!
TireIron is offline   Reply With Quote
Old 03-09-2008, 12:48 AM   #6
Hardwareman
Vehicle Year: 1995
Vehicle Make: Ford
Default
OK guys, problem solved!
I don't know what fixed it other then maybe installing a new tailshaft on my transmission for the vehicle speed sensor, replacing the original lower radiator hose that was leaking a little coolant, or just not driving it long enough after the engine tranny swap thing.
It's running as good as it ever has right now! I'm glad I took my time putting it back together right! I love it again!
I have only "ONE" problem now and that's my power steering pump not working right at lower engine rpm's. I think I need to get some water out of it though.
After that though, this is like a new truck again! Thanks guys!
Allen
__________________
2.5 Swap
Old 03-09-2008, 09:03 AM   #7
red85
red85's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
Try flushing the power steering pump with some fresh fluid and some conditioner. When you say it's not working right at lower rpms, what exactly is happening?
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
