Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 04-25-2012, 11:50 PM   #1
FreeFloat
Vehicle Year: 1997
Vehicle Make: Ford Ranger
Vehicle Model: XL
I use this vehicle for: Toy hauler and mobile ham radio shack
FreeFloat is on a distinguished road
Default Front wheel bearing - how long do I have?
Just bought a(nother) Ford Ranger, 1997 year, it's 4WD with manual locking hubs. (and the 4.0L 6cyl engine in case that matters). The passenger side front wheel bearing is starting to go. Currently it's making a whirring/buzzing noise. I realize it's gonna need replacing, and I'm shopping around for new parts, but how long can I drive this truck? Not that I'm exactly planning a road trip but I'd like to know if I shoul 'park' it right now and use the car to get to work, or can I still make little routine trips around town.
The only reason I'm a bit paranoid is after witnessing a 2002 Ford Explorer 4WD truck's front wheel bearing go from slight *scritch, scritch* noise to loud truck-shaking buzz within 3 days - and then the wheel CAME OFF while I was driving!! Now, I *did* go and do an online search and discovered that the Exploder's wheels do have a recorded tendency to do this as soon as the wheel bearings "go" - they seize and heat up in short order, which blows the backing plate off the wheel which allows the wheel to strip its own lug nuts off and fall off, too. On the other hand I personally knew a guy who drove around for more than a year with failing wheel bearings on his Mercury Sable.
Can anyone advise me here? I realize there are ?no guaranteed, but I'm kinda curious about the trend overall. How long will wheel bearings last from first audible detection before total failure?
__________________
Lurch, the Zombie Truck - back from the dead, after a full freshwater drowning! (97 Ranger XLT, 3.0L 5-spd 2WD)
Barney (97 Ranger XL, 4.0L 5-spd 4WD)
FreeFloat is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 04-26-2012, 12:00 AM   #2
wahlstrom1
J-man HD Mech
wahlstrom1's Avatar
wahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the rough
Default
If it's making noise, get new ones now... Mine made it over night, from squeaking coming home from work to full on seizing failure in 15km the next day.
wahlstrom1 is offline   Reply With Quote
Old 04-26-2012, 12:02 AM   #3
aspevacek
Premium Member
aspevacek's Avatar
Vehicle Year: 97
Vehicle Make: Ford
Vehicle Model: Ranger Splash
I use this vehicle for: wife drives it to work
aspevacek will become famous soon enough
Default
Personally if you are hearing wheel bearing noise it is already to late and the vehicle should be parked for your saftey and others on the road. When a wheel bearing locks up it can do alot more damag ethen just having a wheel come off the vehicle. It will most likely damage the spindle and hub assembly as well. Addign to the cost of thing what will have to be replaced. If the wheeel comes off you would end up looking at brake lines, rotor, brake caliper, front suspension components and most likely some body work depending on the direction the wheel comes off. The look at the fact it is a front wheel and if you have any speed at the time it decides it is no longer hangin g out with you the vehicle could actually roll making fo ra really bad day for you and anyone else on the road around you.
aspevacek is offline   Reply With Quote
Old 04-26-2012, 12:14 AM   #4
UrbanRedneckKid
UrbanRedneckKid's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Taking all my time and money
UrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the rough
Default
Do it right now, or you'll be putting a spindle on it when the bearing starts to lock up.
Run it after that and the inside brake pad will fall out.
Run it longer than that and you'll ruin the lock-out.
Run it even longer and the spindle will start to tear into the inside of the wheel.
Then make a slight left turn and the only thing that'll connect your wheel to the truck will be the brake hose.
This is exactly what happened to mine in only 35mi.
Sent from my PG86100 using Tapatalk 2
__________________
94 Ranger, just slightly modified.... Trailer queen
99 Explorer, EB package, 5.0
88 Ranger, 4/6 drop, 93 powertrain/ dash swap
http://www.therangerstation.com/foru...ad.php?t=33396
UrbanRedneckKid is offline   Reply With Quote
Old 04-26-2012, 12:40 AM   #5
--weezl--
June 2011 OTOTM Winner
--weezl--'s Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger FX4 Level II
I use this vehicle for: stealing candy from babies, and sometimes driving to work
--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute
Default
my drivers side went from bone quiet, with a little noise around right corners, to this (see video) overnight...
http://www.youtube.com/watch?v=m0WliMa9GjI
and what happened when i removed the wheel
http://www.youtube.com/watch?v=xVR9ocgsELU
__________________
Quote:
Originally Posted by Insanejughead View Post
Don't worry Weezl, if you're banned I'll petition to have you brought back.
Quote:
Originally Posted by multiranger View Post
I asked my girlfriend to measure it for me.. It's only an inch
check out my build thread
--weezl-- is offline   Reply With Quote
Old 11-02-2013, 12:13 PM   #6
makuloco2000
makuloco2000 is on a distinguished road
Default
old thread but many may read and wonder how to change as this is a very common issue. Here is my video on how to get it done.
http://www.youtube.com/watch?v=epVAlu-aQeI
makuloco2000 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
