| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc. |
Thread Tools | Display Modes |
#1 |
Junior Member
Year: 1990
Make: Ford
Model: Ranger Super Cab 4x4 stx
Engine: 331 stroker
Class: 4X4
Used For: Taking up shop space
Rep Power: 8 ![]() iTrader: (0)
Hey guys, i am looking for some info on axles for the dana 44. I have a dana 44 from a 78/79 f150 that I am narrowing to early bronco width. What I need to know is are the 76/77 early bronco outer axles or stub axles the same as the 78/79 f150/bronco? I need to get different axles anyways and just wanted to know what i need to order for the outers.
Tweet
#3 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9l
Class: 4x4 off-Road
Used For: daily driver and off road wheeler
Rep Power: 4 ![]() iTrader: (0)
The u-joints are smaller in the classic bronco axles. If you are narrowing the f-150 axle then just shorten the passenger side. Then you can send the passenger side inner axle shaft to dutchman axles to get it shortened and re-splined. That's the easiest and cheapest way to do it. That's what it did.
Tweet
#4 |
Oct 09 OTOTM
Year: 1996
Make: Ford
Model: Ranger SC 4x4
Engine: GT-40 5.0L EFI W/AC
Class: 4x4 EXTREME DD
Used For: Anger Management
Rep Power: 26 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (29)
Narrow it exactly 6 inches, and send the shaft for cut/respline. If you break it, give bronco graveyard a call for a replacement shaft for $75 (760 joint), if you want to get a complete axle shaft set, they gave for $275 for a 6 piece set(4 shafts and 2 spider 760 joints). For $295, you get the 6 piece set with a lifetime replacement warranty.
SVT
__________________
Member of the Turkey Bay Crew SVT Build Thread (96 V8 Ranger) ST Build Thread (02 V8 Sport Trac) V8 swap Club/Info |
Tweet
#5 |
Yes the outers are exactly the same spline count/dimensions except for the u-joint is smaller with the EB stuff.
HOWEVER - make sure you get the right LENGTH outer - there are three different ones available.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread 1996 Ranger XLT 4x2, 2.3, M5OD 1986 F150 4x2 302/T18 1985 F250 4x4 460/T19 |
Tweet
#6 |
Junior Member
Year: 1990
Make: Ford
Engine: 331 stroker
Class: 4X4
I was planing on ordering a chrome Moly axle kit like this one: http://broncograveyard.com/bronco/i-...warranty-.html
I know I have to shorten the passenger side 6 inches and I believe the drivers side a bit but I just want to make sure the outers were the same between this EB Kit and the 78/79 Kits. |
Tweet
#7 |
Cool, that is a good kit. I'd also recommend checking out Nitro brand shafts... one of the local shops sells them and they are supposed to be much better than most of the other brands on the market right now. I believe a set with u-joints was about $560 shipped.
Or you could just do like I did and put RCVs in it and be done forever.
__________________
Tweet
#8 | |
Year: 94
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 lifted
Used For: throwing money at, and swearing at
Rep Power: 6 ![]() iTrader: (0)
Quote:
Also will an early bronco short side inner work for a full size short side inner?
__________________
The Pretty One- 94 Ranger 4.0/auto 4.56 locked 35" Thornbirds The Haggard One- 91 Ranger 2.9/fm146 4.88s spooled, 39.5 TSLs Ox Superwinch |
Tweet
#9 |
EB will NOT work for a 78-79 axle. It may work for the earlier high pinion, 77 and earlier. Can't remember for sure.
__________________
Tweet
#10 | |
Oct 09 OTOTM
Year: 1996
Make: Ford
Quote:
Looks like they have went up on there prices. When I last checked this set was with spicer 760's for $295.... SVT
__________________
Tweet
#11 |
Year: 94
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 lifted
Oh ok. What about the outers? Will the outers in the early bronco kit work with a 78-79 full size knuckles?
__________________
Tweet
#12 |
Yep, the only difference between factory outers is the u-joint size (and length in some cases)
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
