Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 06-23-2012, 08:13 AM   #1
a31ford
Electronics GURU
a31ford's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT (Custom Frame) With a 3" body lift
I use this vehicle for: Working on "Breakout Box for ECM's"
a31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to all
Default 2.9 Injector Wiring.....
Morning All..
With a firing order of 142536, one would assume that the 2 sets (A & B) of injector wires from the ECM would be connected to 142, 536 respectively.
Is my 2.9 wired weird IF, it is NOT the above ?
currently it's 324, 156
This makes NO sense to me.... (Help Please)
Greg
a31ford is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-23-2012, 02:34 PM   #2
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
The 2.9 uses a batch fire system. 123 and 456 fire as groups. Cylinder 1 needs fuel, 123 fire. Cylinder 3 needs fuel, 123 fire.
All injectors share a common power buss and the banks are fired by the PCM providing ground to the desired bank. Given that, the injector harness only contains 3 actual circuits, power, bank 1 ground, and bank 2 ground.
One of the things that makes viewing the harness tricky is the physical arrangement of the injectors. They are slanted and form an X pattern as viewed from the front, so the plugs for bank 2 are actually on the same side as the bank 1 spark plugs.
Also, not trying to be a dick, just trying to make sure we are all calling everything the same thing since not everyone gets it right, Ford's cylinder arrangement is:
Front of vehicle
4 1
5 2
6 3
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 06-23-2012, 02:37 PM   #3
a31ford
Electronics GURU
a31ford's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
Well,
I answered my own question, (but as Im writing this I see that ADSM answered it also, TY BTW)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
