Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-09-2012, 10:22 AM   #1
ilove2bike
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B4000
ilove2bike is on a distinguished road
Default 94 Mazda B4000 starting problems
I just got a 94 Mazda B4000 Manual 4x4. The truck was owned by someone who wasn't driving it regularly for about 6 months. It started with no issue when i first got the truck but not too long after I've started having issues. actually right after I bought my first tank of gas after burning through what was in the tank. Tired some fuel injector cleaner but it made no difference. Not sure if the fresh gas is related though. It seems to start more easily when it's cooler out but if its real hot I will need to crank it for a good 10-15 seconds before it fires and then it slowly comes up to idle. I've noticed if i crank it over for a few seconds then turn the key back to off and try again it will fire up with no issue. I've also noticed that it seems to be a little bogged down when just getting rolling in first until i get to maybe 1500 to 2000 RPM. Also if its real hot out it sometimes smells like it's running a bit rich. I can pick up a faint odor of fuel.
ilove2bike is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-09-2012, 01:06 PM   #2
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Welcome to The Ranger Station!
Sounds like a fuel problem, eh?
Try turning the key to Run (do not crank the starter, but the dash lights come on and test), wait 3 seconds while the fuel pump "primes" and shuts off.
Turn the key back to Off and repeat back to Run, wait, THEN Crank it over.
If that clears up the problem, continue to do that until you decide to replace the fuel pump, or forever. Sometimes the fuel filter will seep, causing the same symptom, so go ahead and try a new filter (cheap enough), but my guess is that the check valve in the fuel pump has gone bad, letting fuel pressure bleed down.
This is very common. It is also a good idea to "prime" any fuel injected vehicle before cranking the starter. Saves wear and tear on the starter and battery.
I would replace the spark plugs too. That'll give you an idea how the engine is doing, if you "read" the old spark plugs. Put Motorcraft double Platinums in it!
__________________
If at first you don't succeed, RTFM.
82 GL1100 Bratbike
93 GL1500I DD
99 Valkyrie IS
08 Rav4 Sport "boring"
Earl43P is offline   Reply With Quote
Old 08-12-2012, 09:08 PM   #3
ilove2bike
Vehicle Year: 1994
Vehicle Make: Mazda
Default
seems to be a bit better but not perfect. I think ill replace the pump and filter and see what happens.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
