Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-22-2012, 03:37 PM   #1
1991fordranger
Vehicle Year: 1991
Vehicle Make: ford
Vehicle Model: ranger
1991fordranger is on a distinguished road
Default easy way to change the radius arm bushings
what is the easiest way to change the radius arm bushings on my 91 4x4 ranger?
__________________
1991 xlt ranger, black mickey thompson classic II rims, 31" mickey thompson mtz's,2" coil spring spacer, flowmaster exhaust,2006 emblems,philips headlight bulbs,tinted windows,toolbox,kenwood radio
1991fordranger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-22-2012, 03:43 PM   #2
brinker88
11/2013 OTOM Winner
brinker88's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Weekend Warrior
brinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to behold
Default
Remove 1-1/8" nut on the end of the radius arm. Cut the rivets out (should be two or three per side if they've never been changed) and remove the 4 bolts still holding the hanger on. Remove hanger. Replace bushings and bolt it back together.
__________________
Obsession is a word justifying your insanity. We ARE the 4x4%.
Apple Hill 4x4
brinker88 is offline   Reply With Quote
Old 08-22-2012, 03:45 PM   #3
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Vehicle Model: BroncoII
I use this vehicle for: Leaving me stranded, broke, and madder than you can imagine.
rangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nice
Default
You could remove the rad arm brackets if they have been replaced in the past, if they are the originals they will be riveted on, I replaced my bent to crap and cracked brackets with the bushings at the same time since both needed it. But other than that, the bushings aren't fun to get at.
__________________
My 2.8 is about to have an out-of-body experience....permanently in liu of 4.0
rangerbum is offline   Reply With Quote
Old 08-22-2012, 03:58 PM   #4
snoranger
Premium Member
Tetris Champion
snoranger's Avatar
Vehicle Year: 94,94,95,01
Vehicle Make: All 10 are Ford
Vehicle Model: Ex, Cobra, Ex, Ranger
I use this vehicle for: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
Quote:
The EASIEST way is to drop it off at a local shop, say "replace these", and pick it up when its done.
The quickest way I've found is to remove the nut off the arm and the pivot bolt from the beam (leave the shock, spring, brakes, sway bar, etc attached). Pull the whole assembly forward about 2 inches, replace the bushing and reinstall everything.
__________________
'95 Explorer -- Cummins 4BT swap in progress.
2015 F150 Supercab Lariat, 5.0, 4x4, heated/cooled leather, nav, (Ford throws so much crap into these trucks, I don't know where to begin)
4BT swap thread
Ranger bed trailer build
ASE Auto and Med/Heavy Truck Master Tech.
snoranger is offline   Reply With Quote
Old 08-22-2012, 07:38 PM   #5
alwaysFlOoReD
I want a belly rub...
alwaysFlOoReD's Avatar
Vehicle Year: '91, '94, '77
Vehicle Make: ford
Vehicle Model: ranger, ranger, f-250
I use this vehicle for: 4x4 race, 4x4, towing
alwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud ofalwaysFlOoReD has much to be proud of
Default
^^^ I didn't remove pivot bolt, and used a 2" ratchet strap to pull the beam forward enough to drop the arms out.
Richard
__________________
My aspirations; Good thoughts, Good words, Good deeds.
alwaysFlOoReD is offline   Reply With Quote
Old 08-22-2012, 07:55 PM   #6
snoranger
Premium Member
Tetris Champion
snoranger's Avatar
Default
Quote:
Richard
I do that on the drivers side, but the pass side doesnt always move enough to do it that way.
__________________
4BT swap thread
Old 08-22-2012, 08:57 PM   #7
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Richard
I tried that with a come-along... and quickly quit when I saw the truck was trying to roll off the jackstand. I had it tied to a tractor infront of it and it might of worked if I had another tractor that moved handy to tie it to from behind but that is a lot of force to put the front end through. I was sliding the rear tires with it as it was...
I ended up cutting an X into the head of the rivets with a cutoff wheel and zipped them off with an air chisel which went very slick.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 08-22-2012, 09:02 PM   #8
brinker88
11/2013 OTOM Winner
brinker88's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
You dont need to have it on jackstands at all.
__________________
Apple Hill 4x4
Old 08-22-2012, 09:02 PM   #9
Destroyer000
January 2009 STOTM Winner
Destroyer000's Avatar
Vehicle Year: 1995 1999
Vehicle Make: Ford Ford
Vehicle Model: Ranger 4x4
I use this vehicle for: work, dd, trail, race
Destroyer000 will become famous soon enough
Send a message via AIM to Destroyer000
Default
we just did this to my buddies truck. jacked up on the frame right behind the mount. enough to were the tires is on the ground still.. take a ratchet strap and we tied it off to his front bumper... custom bumper.. and it pulled it forward enough to get the radius arm out. just make sure you disconnect your sway bar
__________________
95 4x4 35 bfg 15x10 soft 8s custom front/rear bumpers,xrc8 winch explorer disc 4.88ls axle locked d44 EB axle sas power leather explorer seats, OHC, m1354, 04 SOHC 4.0 swap 00 4 door cab swap
99 4x4 converted to 5 spd SOHC swap k/n intake avm hubs, 32 bfg on dc1s, ohc, sport trac leather seats/console 4 inch super lift 01 front end swap power dome hood
Destroyer000 is offline   Reply With Quote
Old 08-22-2012, 09:15 PM   #10
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
Quote:
Since the truck was sliding ahead and the RA wasn't coming out of the bracket it doesn't really matter much. I don't see how I could get an impact on the swaybar bolts with the wheel in place.
IIRC I had the spring and shock out for replacement already so it was just a limp beam sitting on a floorjack, I was killing a bunch of birds while I was there.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
