Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 08-29-2012, 08:57 PM   #1
wr250rdr
wr250rdr's Avatar
Vehicle Year: 1997
Vehicle Make: ford
Vehicle Model: ranger. 2.3
wr250rdr will become famous soon enough
Default Differential skid pan
Does such a thing exist? I plan on lowering my ranger with a 3" beam kit in the front and an exp axle flipped in the rear. My issue is that I live on a dirt road that has a tendency to have large rocks placed in inconvenient areas. So much so that even with a 1/4 inch thick skid pan on it, a rock managed to punch a hole in the cast oil pan of my Volvo.
So my interest in it is to keep from punching a hole in my differential on a similar when I lower my truck down
wr250rdr is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 08-30-2012, 07:00 AM   #2
Dugan
Dugan's Avatar
Vehicle Year: 1989, 1949
Vehicle Make: Ford, IH
Vehicle Model: Ranger, KB-1
I use this vehicle for: DD & FUN
Dugan will become famous soon enough
Default
You could prob make one to work that bolts in the front of the diff housing, but you would need larger bolts... or just weld a peice of metal onto the arm below the diff.. any padding would help.
Dugan is offline   Reply With Quote
Old 08-30-2012, 10:29 AM   #3
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Vehicle Model: BroncoII
I use this vehicle for: Leaving me stranded, broke, and madder than you can imagine.
rangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nice
Default
But the differential won't be getting any closer to the ground. When you lower it, the springs and body will sit lower, but unless you are putting on tiny little tires, the diff will be the same distance off the ground. So if you aren't having issues as you sit already, you've got no worries mate!
__________________
My 2.8 is about to have an out-of-body experience....permanently in liu of 4.0
rangerbum is offline   Reply With Quote
Old 08-30-2012, 10:34 AM   #4
brinker88
11/2013 OTOM Winner
brinker88's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Weekend Warrior
brinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to behold
Default
Get the grinder, welder, and steel out, and go to town my friend!
__________________
Obsession is a word justifying your insanity. We ARE the 4x4%.
Apple Hill 4x4
brinker88 is offline   Reply With Quote
Old 08-30-2012, 04:19 PM   #5
wr250rdr
wr250rdr's Avatar
Vehicle Year: 1997
Vehicle Make: ford
Default
I do plan on running lower profile tires Right now I have 245 70s and I want to put probably 40 series rubber on it do the diff will be lower
Old 08-30-2012, 05:33 PM   #6
killj0y
Premium Member
killj0y's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger XLT Standard Cab
I use this vehicle for: DD and light duty
My credo: Fix it till its broke!
killj0y is a jewel in the roughkillj0y is a jewel in the roughkillj0y is a jewel in the roughkillj0y is a jewel in the rough
Default
Quote:
Yes but total diameter is what matters that's why they are low pro not smaller.on normal tires the rubber makes up a fair chunk of the diameter. On low pros the rim makes up most of the diameter. So in reality going from average tires to low pros will not change where the diff sits relative to the ground. Now if you were going from 35's or bigger to low pros you might notice a big difference but otherwise what the previous poster said holds true.
__________________
96 Ranger 2.3l 2WD Manual 5 Speed
*Lock-Rite Locker
*4" Rough Country Lift
killj0y is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
