Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 09-10-2012, 09:56 PM   #1
Redneck Youth
Redneck Youth's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Daily Driver
Redneck Youth is on a distinguished road
Default missing at idle
my truck seems to be missing a little bit, only at idle though, i replaced the plugs and plug wires a while back and found one that was inproperly routed... however that is not the problem anymore... ive gone through them 3 times and every one is where it should be... im out of ideas. also it has a certain hesitation when you rev it. if you do just a quick step on the pedal, it will hesitate quite a bit. not sure if they are related. thanks...
Redneck Youth is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-11-2012, 02:34 PM   #2
mike2357
Vehicle Year: 1989
Vehicle Make: Ford
mike2357 is on a distinguished road
Default
have u cleaned the MAF sensor pull it out and DON't TOUCH IT spray it off with plastic safe electronics Cleaner or MAF spray see if that helps my mechanic says he dose to every car that comes in to his shop even if its just for an oil change and people are amazed how a oil change made it run so much better
mike2357 is offline   Reply With Quote
Old 09-11-2012, 08:38 PM   #3
Redneck Youth
Vehicle Year: 1994
Vehicle Make: Ford
Default
ive not cleaned it. ill try that
Old 09-12-2012, 12:40 AM   #4
Brownie Mobile
Brownie Mobile's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: F-150
I use this vehicle for: wrecking s***
Brownie Mobile is on a distinguished road
Default
I'm having similar problems glad to see im not the only person missing, Red does yours get better even at idle as the engine gets hot i miss at least once every cycle when its cold but after a good bit of driving or idling it will go away. And ill try the MAF thing tomorrow but i dont have any fancy spray anything else i can use?
__________________
Quote:
Originally Posted by stegomon View Post
but did it have a rocket launcher?
Quote:
Originally Posted by ASMODEAN View Post
No but I bet it had leaky valve covers and a noisy power steering pump...
Brownie Mobile is offline   Reply With Quote
Old 09-12-2012, 01:32 AM   #5
509lifted
509lifted's Avatar
Vehicle Year: 1984,1992
Vehicle Make: ford
Vehicle Model: bronco 2, eb explorer
I use this vehicle for: stock right now besides sound system and air horn and push bumper
509lifted is a jewel in the rough509lifted is a jewel in the rough509lifted is a jewel in the rough509lifted is a jewel in the rough
Default
brownie if i am correct the 2.8 doesnt have a maf
__________________
Quote:
Should I put the reciever pin in the first hole or the back hole? And I'm being serious, no jokes! I think the first hole would be stronger but it fits in the second hole better. Wow this really sounds bad!
thats what u find when u search other forums haha
Quote:
You think a guy would change out his duct tape before snapping some pics.......
509lifted is offline   Reply With Quote
Old 09-12-2012, 06:59 AM   #6
Redneck Youth
Vehicle Year: 1994
Vehicle Make: Ford
Default
mine doesnt seem to get any better, theres always a slight miss.
Old 09-12-2012, 07:45 AM   #7
hopster
hopster's Avatar
Vehicle Year: 1990,1989
Vehicle Make: Ford
Vehicle Model: B2,ranger
I use this vehicle for: wasting garage space
hopster is a jewel in the roughhopster is a jewel in the roughhopster is a jewel in the roughhopster is a jewel in the rough
Default
if your sure it isn't spark then its time to check injector pulse and compression, but i would check spark one more time if it was me.
__________________
I don't wanna grow up.
hopster is offline   Reply With Quote
Old 09-12-2012, 12:08 PM   #8
Brownie Mobile
Vehicle Year: 1985
Vehicle Make: Ford
Default
Quote:
Ah thanks 509, wasnt too sure about that either.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
