Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 10-15-2012, 10:50 PM   #1
Trevor_t2
Vehicle Year: 1998
Vehicle Make: Ford Ranger
Vehicle Model: Stepside pickup
Trevor_t2 is on a distinguished road
Default dreaded gem module
Forgive me if this has been asked before, I am new here. I have a 1998 ranger which has had ongoing issues with what I believe to be the gem module. My wipers, auto windows and now dash lights are being affected. I initially bought a used module from an auto wreckers and swapped it out. It caused my speedo to zoom right to max and it seemed like my fuel was being limited; it ran like shit with no power. I then bought a $400.00 new one from the dealership and had same problems so I returned it. I asked the guy at the dealership if it needed to be reprogrammed or something, he asked the mechanic who evidently said no. They wanted to get me in the shop and start charging me big bucks without offering any ideas as to what the problem may or may not be. It sounded like I was about to get fleeced so I went on my way. I plugged the old one back in and everything worked fine?? It was like this all summer until the rainy season hit again with a vengeance this week and now my problems are back. I now am convinced it is the module and is somehow caused by moisture cause it was early spring and wet when all this began. My question is, I can get another one but didn't have any success the first time with switching it out (caused other problems as mentioned earlier) and I would like more guidance from someone who has experienced this problem themselves before throwing away my hard earned money (seriously, I can't afford to spend thousands on this truck) so any advice would sure help guys, thanks in advance for your input.
Trevor_t2 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 10-15-2012, 11:07 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
The GEM must be configured to the vehicle using fords scan tool.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 10-16-2012, 05:43 PM   #3
Trevor_t2
Vehicle Year: 1998
Default
So if I go back and get the module, plug it in and take it to the dealership they can configure it for me using their diagnostic machine and scan tool? I assume then that they are not simply interchangeable. Why the heck did they seem so vague the first time around, this seems straight forward enough and it could have saved me a ton of headache...
Old 10-16-2012, 06:07 PM   #4
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Quote:
They may have been worried that if they did configure the module for you and it didn't fix your problems that you'd come back at them saying they did something wrong and try to get them to fix it for you.
I know it sounds ridiculous, but I have seen people try it more than once.
Not sure why they would tell you it doesn't need programmed to work right though. That guy was probably just an idjut.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 10-16-2012, 11:44 PM   #5
Trevor_t2
Vehicle Year: 1998
Default
I called another ford dealership today and asked more questions. They said that for 1998 the module should be a plug and go swap out, that reprogramming shouldn't be necessary for that year? He said there was 3 different modules depending on which model truck I own and asked for the numbers off the original module if I was to order a new one. As I cannot GUARANTEE this hasn't been a problem with previous owners, I'm wondering if the module currently in there now was a replacement one (and not the original) that needed to be programmed when IT was installed? At least that would explain why when I plugged in a new replacement that it wasn't configured properly for the truck? Out of all this, I think I will invest in the diagnostic charge for them to at least confirm or deny that it is in fact the gem module. If they tell me they believe it is, then I see no option but to buy one, plug it in and have them spend the time reprogramming it or figuring out why it creates different problems. Try as I might, it looks like I am going to be at the mercy of the dealer; God help me.
I sincerely appreciate your comments, thank you.
Old 10-17-2012, 02:10 AM   #6
Sasquatch_Ryda
Vehicle Make: Ford
Default
Well, seeing as how the shop manual for a 98 ranger states that it is a programmable module right in the re and re steps....
ModuleóGeneric Electronic (GEM)/Central Timer (CTM)
Removal
  1. CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
    NOTE: The generic electronic module (GEM)/central timer module (CTM) must be reconfigured upon replacement. Refer to the New Generation STAR (NGS) Tester help screen on the Ford Service Function (FSF) card to program the Tire Size, Axle Ratio.
    NOTE: When configuring the GEM, the NGS Ford Service Function (FSF) Card version 1.1 will display the following negative response:
    • UNABLE TO PERFORM TEST/FUNCTION
    • SUB FUNCTION NOT SUPPORTED or INVLID FORMAT
    Ignore the negative response. Although the NGS is generating a negative response, it will successfully configure the tire size and axle size selected.
    Disconnect the battery ground cable (14301).
  1. Remove the radio chassis (18806); refer to Section 415-01.
  1. Remove the center instrument panel finish panel.
    1. Remove the screws.
  1. Remove the generic electronic module (GEM)/central timer module (CTM).
    1. Remove the screw.
    1. Disconnect the four connectors from the GEM/CTM.
    1. Remove the GEM/CTM.
Installation
  1. NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    To install, reverse the removal procedure.
__________________
Old 10-17-2012, 02:17 PM   #7
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Please describe the "dash lights" part of your issue.
Reason I say that is there are no dash illumination light circuits in the GEM.
There ARE dash indicator lights controlled by the GEM.
Seat Belt, Door Ajar, 4Hi, 4Low are the ones I see in the 2000 schematic.
Since you did mention a speedometer problem, I can tell that yours is a 2wd. That means that the tire size for speedo cal. IS stored in the GEM, meaning Ford WOULD have to input that value into your new GEM.
The very first thing you should do is clean up the grounds located behind the Parking Brake kick panel and its mate on the passenger side. Should find 3 ground points total, G200 and G203 on the driver side below the fusepanel and G201 on the passenger side.
I also see that the Power Windows Master Switch (driver side) uses G203. The wipers do not have a ground in common (uses G103, located top center of the LH inner front fender).
__________________
If at first you don't succeed, RTFM.
82 GL1100 Bratbike
93 GL1500I DD
99 Valkyrie IS
08 Rav4 Sport "boring"
Earl43P is offline   Reply With Quote
Old 10-18-2012, 11:45 PM   #8
det107
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: DD, Hauling scrap metal
det107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to all
Default
I'd like to chime in that my tach & speedo lights are very dim. The bulbs were replaced & nothing happened-
det107 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
