ncsdaonex
- Dec 5, 2008
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 2.3L 4 cylider
So I have a 1994 ford ranger which I recently repaired, was totalled, has new frame, new front end, wireing redone, swaped from auto tranny to manual. So heres what the truck is now a 1994 ranger 4.0L ext cab, 8.8 rear, 5 speed manual, 4x4 manual hubs. So my problem is ill be driving it and its fine most days but every now and then it just dies while driving and wont start back up, just sputters when u try to start it, the fuel guage will go all the way to full when it does this, sometimes itll kinda idle and the rpms hold steady but the rpm guage jumps all over the place, also the one headlight will go dim when this happens. Ive realized if i keep trying to start it it wont start so I get out and shake the truck and wait a few minutes and it starts right up annd runs fine. Ive checked all wires and there good, also this usually only happens at night and under 1/2 tank of gas if that helps, I originally thought the fuel pump but with the rpm jumping and the headlight diming im not sure. Any idea what could be causeing this. Also any idea why I only get 12 mpg around city driving?
