- Aug 19, 2007
- Age
- 37
- Everett, WA
- Automatic
A few days ago my truck started 'bucking' as if I was repeatedly stomping on the gas. It did it fairly intermittently, and not so much at higher RPMs. I read on here that it could have been the driveline binding so I was planning on checking that, but before I could, it died and now won't restart. I was thinking it was the fuel filter so I checked for pressure at the rail, and it had some, but after checking it a couple times and trying to start it after it sat, I had nothing. I checked the filter, that flows, the pump is good when power is hooked up to it, but when I checked for power on the leads at the pump, I got nothing. I had a friend listen for the relays clicking, and they're good. I was looking into testing the TFI, but Im not sure which test I need to do to check for this, the article in the Tech Library didn't really say much about fuel issues.
Maybe Im going in the totally wrong direction, somebody clue me in.
