No. The only rubbing I had was from a plastic trim piece that had come loose on the driver's side front. It was the trim that is below the bumper and wraps around, I reattached it and no problems.
Yeah,31x10.50x15 on the stock rims. I put them on before I found this site, so didn't know about backspacing or anything like that. Still not sure what it is. The tires give me about 9" of clearance at the rear diffy, which looks like the lowest part.
i might run 30x9.5x15's for a while with a 2" spacer up front....i don't really want to do a body lift after seeing a couple pictures with the bumper in the factory location....
