Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 01-26-2013, 08:01 PM   #1
rivetc78
Vehicle Year: 2008
Vehicle Make: Ford
Vehicle Model: Ranger
rivetc78 is on a distinguished road
Default Cold Weather Starting Issue
Hello everyone, well, with the cold weather upon us in Canada a weird condition has started occuring with my 2008 Ford Ranger XL 2.3 5spd.
At temperatures just below freezing, there is a slight 1 second delay between turning the key to start position and the starter rotating.
As the weather gets colder, instead of the delay, there is a loud click that happens 3 times, the dash lights flash and then the starter starts turning.
So far it's started every time but I'm worried the problem is going to get worst. Once the starter starts turning, it turns at a good speed; it's just that weird hesitation on cold days and the clicking on really cold days.
The truck has 55,000 miles on it and I still have the original battery and starter. I checked the battery connections and they were tight. When the weather is warm or the truck has warmed up to normal operating temperatures, the starter works perfect.
Any ideas?
rivetc78 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-26-2013, 08:05 PM   #2
kunar
Odd One
kunar's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
kunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to all
Default
the battery is 5+ years old, i wouldnt be surprised if its on its way out. cold weather just makes it that much worse. ive never heard of the clicking/flashing stuff though.
__________________
1987 Ranger Supercab STX, 4.0/M5OD/BW1350 4.10 8.8/D35, 3" Lift, Cut Fenders, 33's
1987 Thunderbird Turbo Coupe (Mostly stock, for now...)
1991 Escort GT (Daily Driver)
Past: 87 Supercab, 87 Longbed, 89 Shortbed, 96 Explorer Sport
kunar is offline   Reply With Quote
Old 01-27-2013, 10:46 AM   #3
Andy D
Vehicle Year: 94
Vehicle Make: The Rat
Vehicle Model: 4x4 4.0 5spd Vise grip shift 1354 E, manual hubs
I use this vehicle for: mini pick up stuff
My credo: to prevent Found On the Road Dead, Fix Or Repair Daily
Andy D has a spectacular aura aboutAndy D has a spectacular aura about
Default
In older stuff, that could be either the solenoid or the starter drive. There is a mechanical action and stuff gets sticky in the cold. If it is the battery, it will get worse in a hurry.
Andy D is offline   Reply With Quote
Old 01-27-2013, 01:10 PM   #4
RonD
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
I would check or have the voltage checked on the battery, 12.5vDC and above is OK, below that means battery is on it's last legs.
When it is cold the chemical reaction that takes place in the battery that allows it to store and discharge power is slowed down, the colder the slower.
A battery that is older and already weaker will have an even slower reaction time.
When you turn the key to start position the power draw on the battery heats it slightly and chemical reaction will eventually provide enough power.
The click is the solenoid closing but there is not enough power to pass to the starter yet, multiple clicks is just the battery warming up.
A solenoid is a high amperage relay, you don't want to run 100+amps though the key switch, so the key in start position activates the solenoid to cause larger high amperage contacts to close and send battery power directly to the starter.
The lights should go off when key is in the start position, that is a function of ignition switch and relays.
Car/truck electrical systems disable accessory power when starter is engaged, this is done to provide all available battery power to the starter.
So the flickering lights would be a sign of the same lack of available power when starting in colder weather.
A load test on the battery would tell you more.
And as said above the hardware, i.e. starter, solenoid and cables can also create a resistance in the circuit in colder weather which could show the same symptoms.
But at 5 years old the battery would be my bet.
RonD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
