Testing RPM/TACH
lilfordrunner
4.0
When checking the RPM/TACH with a multimeter and inductive clamp I get many different readings.
Let me start off by saying, the truck is idling high (still haven't figured out why) around 1900-2000
When you are on the right bank of spark plugs and you put the inductive clamp on right side up you get double what the tach says. if you flip the clamp upside down, you get a pretty accurate read (upside down being the opposite of the the directions say to do)
on the left bank of spark plugs with the clamp right said up you get nearly triple the reading, and upside down you get nearly have the reading from the Tach.
Any ideas?
(93 4.0 dropped into an 87 ranger)
adsm08
Senior Master Grease Monkey
Ford Technician
3,639
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Inductive clamp tachs are hard to use on waste spark systems because both sides of the coil fire every time. Since the inductive clamp style determines engine speed by watching spark pulse along the wires and assuming one spark per two revolutions of the engine, waste sparks read about double.
Why it's doing crazy stuff on the driver's side, idunaugh.
Similar threads
Staff online
Members online
Today's birthdays
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
