- Jan 23, 2010
- Reaction score
- 80
- Location
- ND
- Make / Model
- Ford Bronco II
- Engine Type
- V8
- Engine Size
- 5.0
- 2WD / 4WD
- 4WD
- Total Lift
- 2" body. 1.5" coil spring spacers/rear block
In a few weeks I will be starting my V8 swap on my 84 BII.
I have a 5.0 from a 96 Explorer that I parted out with most of engine related components I thought I would need when I originally intended on putting this in my 90 Ranger, which I'm now parting out due to too many project vehicles, not enough time or space (or money, for that matter).
I've also amassed most of the parts needed to put the V8 into my Ranger and most of the parts will still be used to put it into the BII:
M5OD-R2 from circa 90 F150 with
new slave, clutch and flywheel for 90 F150
Mustang Convertible engine mounts
plugs, wires, gasket set for the 5.0
New fuel pump for my 90 Ranger (doesn't cross reference to any year of BII, so this probably won't get used)
Explorer radiator
I will try to use my existing electric fan in the BII
8.8 from Explorer will find it's way under the BII, as well as the Dana 35 from the Ranger (this way the gears will match, 3.73s)
Other parts collected as well, just can't remember all of them off hand.
My original intent was to swap the Explorer V8 into my Ranger with the Explorer ECU so I can keep the DIS, and use as many existing parts as possible to keep the costs down, which ironically would require me to purchase a tuner to disable the rear O2 sensors and the tranny functionality of the computer, but this would allow me for future expansion if I ever decided I needed more power.
So, basically, I want to just use the BII as the swap platform instead of the Ranger and purchase as few extra parts as possible. I want to put an Explorer 5.0 with factory electronics into a carbed 84 BII (probably build a box in the engine compartment for the computer). Is this the most difficult way to do this? It seems most people revert back to OBDI from 90s Mustangs to do their swaps. What problems should I expect?
I expect getting fuel to the engine to be the biggest change required to make this work. Can I just buy an external pump and new high pressure fuel line or should I try to scavenge the fuel system from the Ranger before I part it out? The pump I have won't work on the fuel tank in the BII since this is the 84 with the old style tank and if I bought a newer tank I would still have to buy a new pump since the Ranger fuel pump doesn't cross reference to a fuel injected BII. Also, the current fuel tank in the BII is brand new. Bought it less than a couple hundred miles ago (about a year ago) before I planned on putting a fuel injected engine in there.
What else should I try to grab from the Ranger that will help with this swap? I need to get rid of the Ranger before I start the swap on the BII due to the limited room I have to work/store vehicles.
I could also just take the EFI off but I like EFI for driveability and fuel economy. Also, I think making this a carbed engine might be more expensive at this point since I would have to get a distributor and a new intake manifold (I have a 2150 with 1.21 venturi that could be used) and other miscellaneous parts.
Explorer radiator
