Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 04-12-2008, 08:53 PM   #1
lhc_cj7
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger
lhc_cj7 is on a distinguished road
Default Gas Tank Filler hose replacement
My son's first vehicle, 96 xlt, 4x4, 4.0, automatic, 120k. Paid $2800 and the seller just installed brand new 33's. Since buying it several weeks ago I have been going thru it. So far changed plugs (not to bad on the driver side, removed the radiator return hose and heater hose on the pass side. Made things lots easier) flushed radiator, and then found the gas tank filler hose with a band aid while checking things under the truck.
So after some research I decided to remove the bed. Used krol oil (penetrating oil I get from work) on the bed bolts on top and underneath. Removed the filler hose, had a tube bumper so took that off and while my son lifted the back end removed the wire harness. Two 15 year olds on the sides and the old man on the back lifted right off. Took about 2 hours but I was taking my time.
Moved it to the side of the garage
Here is a close up of both ends. Notice the dry rot on the tank side. Several of those cracks go all the way thru. ouch. This was a Vegas truck before ending up here in Havasu. Can you say 115 all summer long. Might be the cause of the 1443 code (or not.) We will see.
Entire hose
The truck as it sits ready for transmission removel to replace seals.
Anyway, can't find the hose at the many auto part stores. Did find one on the net for $150. It said fits the standard 6 foot bed, this one is 7 feet. The pic looks the same as ours. What would the Ford dealership charge for this??
Anybody have a source for this hose?
Thanks
lhc_cj7 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-12-2008, 08:58 PM   #2
odie1969
odie1969's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: 87 stx
odie1969 is on a distinguished road
Default
search this topic I beleive it was just brought up last couple of days. but i think ford wants 300 for that item.
__________________
Plz no grammer NAZIS I know my spelling and grammer sucks. thanks.
2001 ranger 3.0l 2wd posed out with prerunner fronts. Sold
1987 ranger 2.9l 4wd stx (swaping in 4.0l sohc trans and 8.8) For sale
1969 mercury cougar conv. 351w virgin as mary
1964 MG Midget 1275cc motor
1996 mustang Gt conv. 4.6l steeda susp. parts Sold
2004 f350 king ranch
2007 Expedition El Limted
odie1969 is offline   Reply With Quote
Old 04-12-2008, 09:11 PM   #3
Rarasranger
Junior Member
Rarasranger's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger Ext Cab 2Wheel Drive
Rarasranger is on a distinguished road
Default
Yep. Bout $327 is what I was quoted. Fixed it myself with $30 worth of napa 2 inch fuel hose. Search the threads and you'll find our complete replacement info. Lots of people here will point you in the right direction.
I replaced the hose on my 92 Ext Cab and went right out and passed CA emissions.
Kinda tough gettin the hose onto the fuel tank but with a blow drier and WD 40 you can do it.
Best of luck to you!
__________________
The wealth required by nature is somewhat easy to procure.
The wealth required to attain vain ideals extends to infinity.
Rarasranger is offline   Reply With Quote
Old 04-12-2008, 09:16 PM   #4
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Vehicle Year: 1997, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, F350
I use this vehicle for: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
Search junkyards for this item. I can have my bed off in a half hour (I just did it today to fix the same thing.)
You have pulled one bed. Now you know every step and how easy it is.
You can probably get it for 10 bucks and a hour at the junkyard.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 04-12-2008, 11:25 PM   #5
lhc_cj7
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Default
I swear I did search before posting but didn't find anything that fit. Anyway, great idea's. I'll hit napa and see what they have and I'll check out the local marine store too. I'll let you know how it goes.
Old 04-12-2008, 11:33 PM   #6
Southern3.0
Southern3.0's Avatar
Vehicle Year: '96
Vehicle Make: Ford
I use this vehicle for: Punishment
Southern3.0 is an unknown quantity at this point
Default
My old '91 Ranger had a hacked up filler hose when i bought it, the replaced the out side hose with what I thought was a napa radiator hose but I geuss if they sell 2" fuel hose thats what it was.
worked perfect though.
__________________
'95 Ranger, single cab, 4 cyl 5 spd, 2wd
'96 Ranger single cab, 4 cyl 5 spd, 2wd. sold.
'02 Edge...Wrecked it
'91 Ranger, picked it up for $300, sold it for $2500
Southern3.0 is offline   Reply With Quote
Old 04-13-2008, 02:34 PM   #7
Rarasranger
Junior Member
Vehicle Year: 1992
Vehicle Make: Ford
Default
Found it! Search "Fuel Filler Neck" and it should come up. Good luck.
__________________
Old 04-13-2008, 11:47 PM   #8
lhc_cj7
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Default
I was surprised to see the plastic pipe from end to end. So what your saying is to get a fuel hose with an ID of 2" and wiggle onto the plastic pipe using heat? Sounds easy enough. Now I see why paying ford the $300 is
Old 04-15-2008, 12:33 AM   #9
Rarasranger
Junior Member
Vehicle Year: 1992
Vehicle Make: Ford
Default
Yep. Just remember to use the WD 40 inside the new hose and some patience when connecting the new hose to the fuel tank. It took some cussing and some sweat to get it on there.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
