Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-22-2008, 08:51 PM   #1
StreetRanger01
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger XLT
StreetRanger01 is on a distinguished road
Default Brake lights not working on 2001 Ranger
I was just wondering if anyone could point me in the right direction regarding the brake lights on my 2001 ranger that I just purchased. I don't know much about electrical wiring and what not in cars but I have heard on some internet boards about a multiswitch, brake switch and fuses. I checked the fuses and I really don't think it is that. Does anyone know if these trucks have a common issue that will help me narrow it down. Thanks
StreetRanger01 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-23-2008, 09:20 AM   #2
addiman09
addiman09's Avatar
Vehicle Year: 2003
Vehicle Make: Ford Ranger
Vehicle Model: 2.3 Liter 5spd
I use this vehicle for: everything
addiman09 is on a distinguished road
Default
did you splice the wires together?
__________________
"I get drunk then hump things"
"Yur"
addiman09 is offline   Reply With Quote
Old 05-23-2008, 02:03 PM   #3
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
Is the 3rd brake light working? or none of them?
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 05-23-2008, 02:22 PM   #4
StreetRanger01
Vehicle Year: 2001
Vehicle Make: Ford
Default
I haven't spiced anything on it. In regards to the third brake light I will go check today, I didn't even think about it and the truck isn't at my place right now.
Old 05-23-2008, 05:03 PM   #5
98greenrangerguy
98greenrangerguy's Avatar
Vehicle Year: 2011
Vehicle Make: Ford
98greenrangerguy is on a distinguished road
Default
If none of your brake lights are working, it may be the BOO (brake on/off) switch located behind the pedal. Have someone watch the brake lights while you push in the switch contact with a screwdriver. You may have to give it a good push. If the light come on, see if you can adjust the position of the switch so that it's closer to the pedal. You can also try using some type of spacer on the contact.
__________________
2011 XLT, 2.3L, 2wd, and power everything
98greenrangerguy is offline   Reply With Quote
Old 05-23-2008, 08:55 PM   #6
StreetRanger01
Vehicle Year: 2001
Vehicle Make: Ford
Default
I checked tonight and all the other lights work except for the three brake lights. I will check tomorrow with the brake switch to see if that is the issue. If anyone has any other ideas feel free to throw them my way as well. I just don't want to replace parts that don't need replaced if I don't have to.
Old 05-24-2008, 12:43 AM   #7
Loanranger
Loanranger's Avatar
Vehicle Year: 1989/ 1972
Vehicle Make: Ford/ Fordzuki
Vehicle Model: Ranger SC XLT/ Mutt?
I use this vehicle for: Daily driver/Jeep Recovery
Loanranger is on a distinguished road
Default
the brakelight switch is pretty cheap iirc, and easy to change, mine went bad so it's a possability
__________________
Sold the ranger
Fordzuki, 72' Suzuki LJ20, w/ '97 2.3 and M50d, locked, geared, linked rear, 34x10.50s
Daily driver, '86 Suzuki Samurai, stock other than geared t-case and a rear lockright.
Loanranger is offline   Reply With Quote
Old 05-26-2008, 09:41 PM   #8
StreetRanger01
Vehicle Year: 2001
Vehicle Make: Ford
Unhappy
Put on a new brake switch on the pedal today and still no brake lights. Not sure what else to check now. Anyone have any ideas????
Old 05-27-2008, 12:13 AM   #9
Loanranger
Loanranger's Avatar
Default
Have you tried actually changing fuses with a known good one? Sometimes the fuses will blow, but it won't look like it is blown. Another thing to check would be grounds, though I would think they wouldn;t all go bad at once.
__________________
Sold the ranger
Old 05-27-2008, 09:06 AM   #10
StreetRanger01
Vehicle Year: 2001
Vehicle Make: Ford
Default
I will give the fuse thing a shot today.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
