Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 06-19-2008, 12:39 AM   #1
ejholmgren
ejholmgren's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD
ejholmgren is on a distinguished road
Default MAP sensor location on '93 4cyl
I have the entire harness laid out in my basement to adapt it to a dizzy/LA3 setup, so I'm trying to get everything straight before I remove all the DIS wiring.
Where is that bugger hiding at?
ejholmgren is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-19-2008, 09:47 AM   #2
shadetree
shadetree's Avatar
Vehicle Year: 1994
Vehicle Make: Explorer Sport
I use this vehicle for: Work
shadetree is on a distinguished road
Default
Your 93 does not have a MAP sensor. 92 and back had MAPs. It is a small black box about the size of a pack of cigarettes mounted on the firewall or fender(depending on model). It will have a wiring connector and a vacuum hose going to it. shady
__________________
Bawney Fwank/Bobby Rush 2012.
shadetree is offline   Reply With Quote
Old 06-19-2008, 11:10 AM   #3
ejholmgren
ejholmgren's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Looks like I'll have to source one and wire it up then, thanks!
Old 06-23-2008, 11:49 AM   #4
Sevensecondsuv
Sevensecondsuv's Avatar
Vehicle Year: Many
Vehicle Make: All Fords!
Vehicle Model: Most of what Ford Made in the 90s!
I use this vehicle for: Life
Sevensecondsuv is on a distinguished road
Default
My 1990 2.3 did not have a MAP. It did however have the cali emmisions package with a MAF. I just wired one in when I put the turbo on. I think it takes VREF and SIGRTN which you can get from just about anywhere under the hood. Then you just have to run one dedicated MAP wire from the computer to the sensor.
__________________
2011 Ford Ranger 2.3 5-spd; 2001 Ford Ranger 2.5 5-spd;
1992 Explorer 4wd 5-spd; 2000 Ford Excursion 6.8 4wd;
1995 Ford F-250 4wd 4.9 ZF-5 D60 SAS;
Past: 1990 Ranger 2.3 Turbo
Sevensecondsuv is offline   Reply With Quote
Old 06-23-2008, 03:25 PM   #5
ejholmgren
ejholmgren's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
I think I'm going to run a vref wire from the tps/egr brown/white out to where the MAF was, use two of the MAF wires for the VAF/VAT, repin the IAT to the MAP, steal the IAT sig return for both the VAM and the MAP, and rewire/repin the CPS to the IAT.
Old 06-23-2008, 04:05 PM   #6
Sevensecondsuv
Vehicle Year: Many
Default
Sounds like you have a good handle on things. I needed to keep the CPS because I'm running the dual plug DIS setup.
People are so afraid of wiring and sensors but when you get into it it's not that bad at all.
__________________
Old 06-23-2008, 10:02 PM   #7
shadetree
shadetree's Avatar
Vehicle Year: 1994
Default
On the turbo the sensor is called a baro sensor for barometric. It the approximate same sensor, but it measures atmospheric pressure instead of manifold pressure. No vacuum hose. Some have said they use the map sensor, just leave the hose off and have no problems. shady
__________________
Old 06-23-2008, 11:29 PM   #8
ejholmgren
ejholmgren's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
I snagged a MAP from a BII in the yard, planning on leaving it open to atmosphere
Old 10-16-2010, 11:12 PM   #9
BroncoV6
Vehicle Year: 1993
Vehicle Make: FORD
Vehicle Model: RANGER 5-SPEED
BroncoV6 is on a distinguished road
Default Adding a map sensor to 93 2.3L Ranger
Can you please draw and email me a diagram of how to add a map sensor to my 93 non-turbo ranger 2 wheel drive. I am not savy to all the VREF and SIGRTN but I can follow a wiring diagram. The fuel economy on my Ranger sucks, but I love the truck.
formyemail at hughes.net
Thanks,
Hardy
BroncoV6 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
