Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-01-2008, 11:10 PM   #1
jkinga1c
Vehicle Year: 1986
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: anything
jkinga1c is on a distinguished road
Default transmission stuck in gear
i have a 86 ranger and put a 302 in it. i put a m5od-2 trans from an 89 f-150 i got from the junkyard. the trans shifted through all the gears when i got it after installing it it wont come out of 1st gear i havent even drove the truck yet and the driveshafts arent installed. nothing was dropped in it i had it covered the whole time it was out. the clutch wont disengage because i dont have the hydraulic line on it yet but the engine wont turn over with the trans on it now either.any help wpuld be appreciated
jkinga1c is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-01-2008, 11:26 PM   #2
Turbo-T
Premium Member
Turbo-T's Avatar
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Ranger, Ol Blue
I use this vehicle for: Daily driver
Turbo-T is on a distinguished road
Default
Sounds like you've got your input shaft in a bind. could be the clutch disc spline is binding or a problem with the pilot bearing. I'll bet if you back off all of the bell housing bolts it'll spring back away from the engine a little bit and you'll be able to shift the tranny.
__________________
If it don't fit, make it fit.
84 ranger 4X4 2.3 turbo.
Turbo-T is offline   Reply With Quote
Old 07-01-2008, 11:43 PM   #3
jkinga1c
Vehicle Year: 1986
Vehicle Make: ford
Default
ok thanks ill try that
Old 07-02-2008, 09:20 AM   #4
MAKG
RBV Technical Advisor
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
MAKG will become famous soon enough
Default
The engine won't turn over with no driveshafts and the transmission in gear?
The transmission is junk. It's in two gears at once. Even if the clutch were welded (along with the pilot bearing), the engine should still turn over.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 07-02-2008, 10:25 AM   #5
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
I HAVE THIS PROB WITH my 5 spd, I was told the keepers are bad. The redneck fix recommended to me was to pull the top half of the keeper and keep rolling. its gonna cost a ton either way, so why not. Im lokoing for a new tranny now but gonna try to run it if i can. auto's and manuals have specific differences, but at the same time the inner workigs are generally the same right? check the keepers.
feellnfroggy is offline   Reply With Quote
Old 07-02-2008, 10:36 AM   #6
rickcdewitt
rickcdewitt's Avatar
Vehicle Year: 1991
Vehicle Make: ford
Vehicle Model: ranger-needs more lift
I use this vehicle for: work and play
rickcdewitt is on a distinguished road
Default
if you put the shifter on wrong you can engage two gears at once locking the tranny,doesn't hurt it if you haven't tryed to start it and let out the clutch. but you won't be going anywhere until you remove the shifter and use a screwdriver to put it in neutral.
if its just stuck in first the linkage may have a problem(sheared roll pin ?)
EDIT:if it really was just stuck in first it would still turn over. i bet you have two of the detents in the tranny both engaged(there are three rods and you must have two of them not centered in their travel)
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8
My bobtail beater
Quote:
Originally Posted by fastpakr
Try to stick to posting about trucks, unless you can figure out a way to control yourself.
rickcdewitt is offline   Reply With Quote
Old 07-02-2008, 10:41 AM   #7
feellnfroggy
Vehicle Year: 1993
Vehicle Make: Ford
Default
was this for me or the original poster? theres another post with same title for my probs, explaining more my problem. But this guy with automatic shifter shouldnt matter should it?
Old 07-02-2008, 03:08 PM   #8
rickcdewitt
Vehicle Year: 1991
Vehicle Make: ford
Default
Quote:
the O.P. of course,his problem is assembly.not extremely worn shifter bushings or whatever you did to your tranny running it into the ground.
auto shifter- WTF?you are posting jibberish.hes got a 5 speed
__________________
My bobtail beater
Old 07-02-2008, 03:53 PM   #9
feellnfroggy
Vehicle Year: 1993
Vehicle Make: Ford
Default
My mistake, I'm still learning the nomenclatures for the ranger trannys, thought it was auto. And I didnt run mine into the ground I've had the truck three weeks. Read the other post.
Old 07-02-2008, 08:13 PM   #10
AllanD
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Ok, I rebuild manual transmissions continuously and don't know what
you are refering to when you say "keeper".
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
