Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-05-2008, 11:17 AM   #1
extremejdk
extremejdk is on a distinguished road
Default Clutch Line? How to Replace??
I swapped in a complete 2.3L + 5speed transmission into my '91 Ranger. To make the pull easier we just snipped the clutch line leading to the slave cylinder but now that I have everything bolted in ... I can't find where to purchase a new clutch line?
Can I use standard high pressure hose? Do I have to use a razor blade or something to remove it from the cylinder nipples?
EDIT* Nevermind, found a clutch line online.
extremejdk is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-05-2008, 04:15 PM   #2
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
There was a thread on this about a year ago...but there are a few lines you can use...but I would just try to get the whole master cylinder/clutch line from a model year that you took the tranny from...
There is a 'quick release' on the clutch line...it's not always easy to get it out and there is a special tool you need to use...but you can also try two screw drivers to peel back the white plastic inside the clip on the transmission side...then pull the entire master cylinder last...I found this to be actually harder than getting the line disconnected from the transmission...
But you're other option is to use a reinforced line...unforutnately I didn't go that route so I have no idea what to recommend...and not even sure if the thread made it to the new website...
EDIT: I just tried searching for clutch line but didn't find the old post where someone recommended a hose type that could be used...must've got lost when we changed sites...
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
