Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 08-28-2008, 10:37 PM   #1
mb3offroadr
mb3offroadr is on a distinguished road
Default My #3 spark plug keeps fouling. What do i do?
i have a 99 ranger 4.0 and in the last year i have fouled my #3 spark plug about 3 times. any ideas on what could be causing this?
thanks in advance
mat
mb3offroadr is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 08-28-2008, 10:54 PM   #2
Sevensecondsuv
Sevensecondsuv's Avatar
Vehicle Year: Many
Vehicle Make: All Fords!
Vehicle Model: Most of what Ford Made in the 90s!
I use this vehicle for: Life
Sevensecondsuv is on a distinguished road
Default
Bad fuel injector maybe.
__________________
2011 Ford Ranger 2.3 5-spd; 2001 Ford Ranger 2.5 5-spd;
1992 Explorer 4wd 5-spd; 2000 Ford Excursion 6.8 4wd;
1995 Ford F-250 4wd 4.9 ZF-5 D60 SAS;
Past: 1990 Ranger 2.3 Turbo
Sevensecondsuv is offline   Reply With Quote
Old 08-29-2008, 06:32 AM   #3
Bob Ayers
Vehicle Year: 1999
Vehicle Make: Ranger
Vehicle Model: St. Cab
Bob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura about
Default
Bad plug wire, bad valve guide seals, or bad rings.
__________________
"you can rant, rave, scream, shout invective, claim infinite experience,
and ultimatly deny that you are wrong until hell freezes, but you are WRONG." Alland
Bob Ayers is offline   Reply With Quote
Old 08-29-2008, 09:07 AM   #4
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
Doubtful on the rings or stem seal being as it is just one cylinder. Wire or injector are a good start.
__________________
'95 Ranger SC, old-type Duff brackets, hoops, springs & radius arms, Skyjacker rear springs, 4.0 5-spd, 13-50 manual, 4.10s, D35 Lockright, 31-spline 8.8 (discs, Trac-Lok), Superwinch Epi 9,000
'09 Mazdaspeed COBB Tuning--small but very angry.
'14 ZX1000M; '09 TU250X; '79 XLS1000
Will is offline   Reply With Quote
Old 08-29-2008, 10:01 AM   #5
shadetree
shadetree's Avatar
Vehicle Year: 1994
Vehicle Make: Explorer Sport
I use this vehicle for: Work
shadetree is on a distinguished road
Default
How is it fouling? Is it carboned up, caked with white stuff, or just not working?shady
__________________
Bawney Fwank/Bobby Rush 2012.
shadetree is offline   Reply With Quote
Old 08-29-2008, 11:50 AM   #6
Evan
Evan's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer Sport
I use this vehicle for: Wheelin
Evan is on a distinguished road
Default
If the injector is sticking in the open position, it will foul the plug. That happened to me on #4.
If you have a leaky valve guide on the intake or exhaust port for that cylinder, you will end up with a fouled plug.
I would guess it's one of the above that's causing your plug to foul.
__________________
2001 Mustang Cobra SVT convertible: 5-speed, 320HP V8, 0-60 in 4.8
2009 Chevy Aveo 5-door LS: 5-speed, DD
Evan is offline   Reply With Quote
Old 08-30-2008, 01:26 AM   #7
dieseltweaker
dieseltweaker's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: its an everyday driver
dieseltweaker is on a distinguished road
Default
mine kept doing that and i had had a small leak in my head gasket and it eventually blew out.
__________________
1994 Ranger - 4.0,throttle body spacer,K&N,modified air box,flowmaster muffler w/ 2.5 pipe in front of the tire,headers,leveling kit,and 25,000 btu trans cooler
dieseltweaker is offline   Reply With Quote
Old 08-30-2008, 02:00 AM   #8
UrbanRedneckKid
UrbanRedneckKid's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Taking all my time and money
UrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the rough
Default
Mine's doin the same thing. when i put the engine(used) in I did a tune up on it. #3 was fouled and had traces of oil on it. I'm thinkin it's a stem seal, cause I have a little poof of smoke when I first start it up.
Can you give anymore details about yours?? How does the plug look?
__________________
94 Ranger, just slightly modified.... Trailer queen
99 Explorer, EB package, 5.0
88 Ranger, 4/6 drop, 93 powertrain/ dash swap
http://www.therangerstation.com/foru...ad.php?t=33396
UrbanRedneckKid is offline   Reply With Quote
Old 08-30-2008, 08:46 AM   #9
Danger06Ranger
Danger06Ranger's Avatar
Vehicle Year: 2006/1986/2001
Vehicle Make: Ford/Mercury
Vehicle Model: Ranger FX4/FSB/Cougar
I use this vehicle for: Daily Driver
Danger06Ranger is on a distinguished road
Send a message via AIM to Danger06Ranger Send a message via MSN to Danger06Ranger
Default
Seriously, they might help.
__________________
LiteSpeed Underground member
2006 Ford Ranger FX4 Off Road
1986 Ford Bronco XLT
http://www.motortopia.com/cars/8399
you cant spell slaughter without laughter
Danger06Ranger is offline   Reply With Quote
Old 08-30-2008, 09:06 PM   #10
MikeMcC
MikeMcC is on a distinguished road
Default
Guys if this is the 4.0 OHV It's extremely likely you have a cracked head or blown head gasket. This is a common problem on all 4.0 OHV's. The tale tell sign is if you are getting a little bit of white smoke on start up.
If would recommend a compression test. You will probably have low compression on the cylinder that keeps fouling plugs.
If replacing the plug fixes the problem for a short time but it comes back, you know it's nothing ignition related, and it's something thats actually fouling the plug. In this case It's almost a 100% certainty that you have a blown gasket/cracked head.
Ways to check for a blown head gasket/cracked head:
1. Slowly loosing coolant.
2. Smoke at start up.
3. Rough Idle.
4. Fouling spark plugs on a regular basis.
5. Inspect the block for coolant leaks around the heads, and pull the spark plugs after they have been sitting for a while to inspect for coolant.
6. Check for coolant for presence of oil.
7. Send your oil off for a used oil analysis. If it comes back with coolant contamination it's most likely a head/gasket.
If it matters I also have a 99' 4.0L that was fouling on #3. Turned out to be a cracked head.
MikeMcC is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
