Cracked cylinder head - Swap options
psmith
15+ Year Member
...got the bad news from the machine shop yesterday; the head i picked up for my '90 ranger is cracked.
to avoid spending another half day at the local pick a part to possibly end up with another good looking but bogus cracked head i'm looking into the option of purchasing a rebuilt one that's ready to go.
should i consider getting a 1995 or newer head to up my compression ratio a bit or should i stick to the first generation (89-94) roller head?
besides the different combustion chamber, different valve stems size, different springs and different water outlet bolt size(?) what other variables am i looking to run into with this swap?
will my 1990 intake manifold fit on a 94+ head?
how much of an increase in compression am i actually looking at, something that i could easily gain by shaving a few thousandths off my '90 head?
sorry for the lengthy post and thanks in advance for any replies.
also, are their any photos available that picture the different combustion chambers shapes over the years?
i tried searching but didn't get back much.
I Think All The Newer Heads Are 8 Spark Plug Heads. Will That Work? In Your Truck.where Was It Cracked On Number 1 Cly. Between The Valves ?
95+ has different mounting holes for alternator bracket and coil.Also 95+ does does not have water passage to the intake.Intake ports are smaller.Only bolt on deal is up to 94 8 plug.
I Think All The Newer Heads Are 8 Spark Plug Heads. Will That Work In Your Truck.where Was It Cracked On Number 1 Cly. Between The Valves ?
my 1990 is an 8 plug head. not positive on the exact location of the crack as i cant make it to the shop until tuesday.
good info, thanks.
any additional differences anyone knows of?
