Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 09-01-2008, 10:13 PM   #1
Spd68ford
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger Four Wheel Drive
I use this vehicle for: Hunting, Fishing and Daily Driver
Spd68ford is on a distinguished road
Send a message via AIM to Spd68ford
Exclamation 4WD High & 4WD LOW Lights
well I own a 1999 Ranger extended cab 4 wheel drive with the 3.0 flex fuel engine. Anyways I am experience a problem where the 4WD High & 4WD LOW Lights on the dash are flashing together every five minutes or so also right after start up and also the truck will no shift into four wheel. Earlier in the day i put the truck in 4 low and put it in 1st gear to ease the wear on the brakes going down a pretty damn steep hill. Anyways has anyone seen this problem or know what the hell is going on i need some help. Thanks
Spd68ford is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 09-01-2008, 10:36 PM   #2
sarasota
Junior Member
sarasota's Avatar
Vehicle Year: 1999
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD, mud
sarasota is on a distinguished road
Send a message via AIM to sarasota
Default
on mine when i put it into 4 low sometimes the 4 high light will come on, but its in 4 lo
are you putting it into neutral before you shift into 4?
sarasota is offline   Reply With Quote
Old 09-01-2008, 10:38 PM   #3
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Vehicle Year: 2009
Vehicle Make: Chevy
Vehicle Model: 2500HD
I use this vehicle for: Shaming Sports Cars
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
The truck senses there is a problem with the 4WD system.
Take it to a dealer and have the codes pulled.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Old 09-01-2008, 10:54 PM   #4
Spd68ford
Vehicle Year: 1999
Vehicle Make: Ford
Default
1st yes its in neutral when I try putting it in 4w ive tried everything to get it to shift and it wont. 2nd jspafford question with the truck sensing a problem with the 4 wheel drive could it be in a safe mode not allowing it to shift in 4 wheel drive. thats what I am guessing
Old 09-01-2008, 11:10 PM   #5
Jspafford
Jspafford's Avatar
Vehicle Year: 2009
Vehicle Make: Chevy
Default
Not normally... It will usually shift into 4wd and then break not allowing it to shift out.
Unfortunatly RBV's are not that smart...
Chances are there is a problem with one of the sensors.
__________________
Old 09-01-2008, 11:15 PM   #6
Spd68ford
Vehicle Year: 1999
Vehicle Make: Ford
Default
I also forgot to mention that the lights began to flash when I was driving down the freeway if that has anything to do with it. another question would be if the oil level in the transfer case is low could that be what turned the lights on or tripped the code
Old 09-01-2008, 11:55 PM   #7
Jspafford
Jspafford's Avatar
Vehicle Year: 2009
Vehicle Make: Chevy
Default
Any issues with your speedometer? Does your O/D light flash?
__________________
Old 09-02-2008, 12:03 AM   #8
Spd68ford
Vehicle Year: 1999
Vehicle Make: Ford
Default
speedometer works like a champ and I dont have an O/D light being that i dont have overdrive which sucks. also everything is working as it should besides the 4 wheel drive and nothing is leaking except for a little bit on the front of the transfer case and I wiped it off looking for a crack or damage and nothing was there guessing the gasket or seal is going bad
Old 05-26-2010, 07:44 PM   #9
ch2112
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger XLT FlexFuel
I use this vehicle for: Everything...
ch2112 is on a distinguished road
Default 4WD High & 4WD LOW Lights
Hello... I have the same problem. I have owned my 99 Ranger FlexFuel for about 8 months and it has now done the flashing 4wd lights twice. Once within 3 weeks of purchasing the truck, and again just today. When this happens, 4wd will not engage, either High or Lo. We pulled the battery and it stops. For now, it seems to be a glitch, but that's not enough of an answer for me.
Has anyone found a REAL reason for this? Or a more reliable solution than pull the battery and hope?
ch2112 is offline   Reply With Quote
Old 05-26-2010, 07:47 PM   #10
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
next time it happens count the flashes and come back with the numbers. It will be x number of flashes, a pause of a few seconds, and then more flashes. It's a fault code, but we need the number before we start guessing at the cause.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
