- Aug 6, 2007
- Age
- 38
- Plattsburgh, NY
1999
so my 96 splash gets 19mpg a gallon! gets this if i baby the truck or if iam hard on it.. highway it gets 24.. its a stepside reg cab 5spd.. my buddies 97 excab fleetside gets 26-28... why would a "smaller" truck a little lighter get worse mileage? hell my 95 4.0 spd lifted gets 19 any ideas?
also the check engine light has come on for a cam position sensor malfunction... i replaced the sensor a while back when the code first came on drove the truck 800 miles was fine.. then it came back on again for the same code... erased the code with my scanner an its fine.. dont understand what would cause this... just does it every once in a while... worn timing belt cause this ?
