Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-22-2008, 03:05 PM   #1
DerangedRanger33
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Everything
DerangedRanger33 is on a distinguished road
Angry 2.9 No Power
My truck has no power at all. its a 5 speed and when im in high rpms it makes a grindind noise that sounds terrible. it dosent do it when the clutch is pushed in and i rev it up to 4 or 5 k rpms. only when im in gear driving. its very slow up any and every hill and the fastest i can go on flats is 40 or 45.
any one have this problem? or hear of it before? any help would be greatly appriciated.
thanks
DerangedRanger33 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 09-22-2008, 03:12 PM   #2
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
First thing to do is pull codes, see if it will tell you whats going on:
http://www.therangerstation.com/tech_library/OBD_I.html
Then check all the Basics: Fuel Filter, Fuel Pressure, Spark Plugs, Wires, Air Filter, Compression etc.
Make sure it is all in working order, may need a tuneup
Is it smoking at all?
Did this just happen or has it been steadily getting worse?
The grinding could be a bearing in the transmission.
__________________
I hate all RBV's. I hate my Ranger most of all.
1989 Ranger build - 4.0 swap, 7.5, Dana 35, 4.56 gearing, Lockers, 5" lift, Electric power steering
1976 Fiat Abarth 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Old 09-22-2008, 03:21 PM   #3
DerangedRanger33
Vehicle Year: 1989
Vehicle Make: Ford
Default
I just did a complete tune up on it. new plugs and wires. oil change. air filter. It seems to be getting plenty of fuel because it revs up fine in neutral
Old 09-24-2008, 12:38 AM   #4
DerangedRanger33
Vehicle Year: 1989
Vehicle Make: Ford
Default
anyone at all have this problem before?
Old 09-24-2008, 06:21 PM   #5
89DangerRanger
Junior Member
89DangerRanger's Avatar
Vehicle Year: 1979/ 2003
Vehicle Make: Ford
Vehicle Model: F150 custom/ svt focus
I use this vehicle for: winter beater and mud truck/ dd driver and ricer burner
89DangerRanger is on a distinguished road
Default
ya mine does it 2, my trans. grinds in 4 because the syncros went out of it and mine doesn't have power going up hill ether, i did a full tune up and replaced the fuel pump, and changed the filter and nothing made it better and mine revs up fine in neutral, i think its just an underpowered engine pushin 30's
89DangerRanger is offline   Reply With Quote
Old 09-25-2008, 02:02 AM   #6
DerangedRanger33
Vehicle Year: 1989
Vehicle Make: Ford
Default
oh ok thank you very much.
so do you think a rebuilt tranny would help at all?
or should i give up all hope with the 2.9?
Mine was super slow with my 33 12.50s!
its a little quicker now with my 31 10.50s
but still cant get out of its own way.
and cant top more than 50 mph on flat ground
Old 09-25-2008, 02:07 AM   #7
DerangedRanger33
Vehicle Year: 1989
Vehicle Make: Ford
Default
and it also dosent make the grinding nose when its cold
Old 09-25-2008, 07:45 PM   #8
ranger
Vehicle Year: 1988
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: waisting gas and money
ranger is on a distinguished road
Send a message via AIM to ranger
Default
i dont have that problem and im running 31's like black said i would try pulling the codes it might be somthing more complicated than just the simple tune up stuf
ranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
