Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-27-2008, 01:09 PM   #1
Chingadera
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Bronco II
Chingadera is on a distinguished road
Default starter soleniod wiring?
Ok just making sure before I fry something. On the starter solenoid on a 1984 BII 2.8 I just connect the positive cable to the solenoid and then on the other side run it down to the starter? Next question wich 2 small wires connect to the solenoid and which post do they go on?
Chingadera is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-28-2008, 09:46 AM   #2
88BII
Junior Member
88BII's Avatar
Vehicle Year: 1988 1985
Vehicle Make: Ford
Vehicle Model: Bronco 2 Ranger
I use this vehicle for: Everythging
88BII is on a distinguished road
Default
the 2 smaller post should be labeled with an s or a. hook the small plug up to the "S" for stater. there should be 2 other wires that are fusible links the hook up on the battery side of the solenoid. lmk if ne prob.
88BII is offline   Reply With Quote
Old 09-28-2008, 02:00 PM   #3
Chingadera
Vehicle Year: 1984
Vehicle Make: Ford
Default
I hope I have the right solenoid? It has 2 post and then 2 small post. One small and one big on each side. Ill post up later if I dont get it right.
Old 09-28-2008, 04:25 PM   #4
Jorley
Jorley's Avatar
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Bronco ll
I use this vehicle for: everything
Jorley is on a distinguished road
Default
Only one small wire goes to the solenoid. It gets connected to the terminal marked with a"S". It is the wire from the ignition switch to actuate the solenoid. The charging system wires hook up to the battery side of the solenoid. I can get a pic if you need it.
__________________
If it don't fit,force it. If that don't work get a bigger hammer!
84 Bll 2.8L duraspark, rv cam, cowl induction
T-K 5, 31x10.5x15
manual T-case and hubs
Jorley is offline   Reply With Quote
Old 10-03-2008, 12:47 AM   #5
Chingadera
Vehicle Year: 1984
Vehicle Make: Ford
Default
Ok I got the starter hooked up and solenoid, thanks. I have some more questions. I can only find one heater hose connection on the upper part of the intake near the front of the motor, where is the other heater hose connected at? There is a ground or something (bolted to the carb mount) attached to a vacume thingy with some kind of one way valve and hose conection. What vacume hose goes to this? Lastly Can someone post pictures of the alernator wires? I will need to make my own to the battery cable and dont know which ones go to the alternator from the harness or were they go on the alternator?
Sorry for all the questions but Im just trying to finish up the project asap.
Old 10-06-2008, 02:22 AM   #6
Chingadera
Vehicle Year: 1984
Vehicle Make: Ford
Default
Need help.
I figured out everything except the ingition coil and alternator.
1st The red wire that goes in the ingition coil wide plug then comes out as a spaid single plug, where does this go? I cant find any place on my harness for this to plug in? Does it just go to the battery??????
2nd I have three wires that go to the alternator where do they go? ones black, ones orange, the other is red/orange with a stripe and is bigger. Im assuming the black goes on the black pin, do the other 2 go on the orange pin and then I need to run a cable to the battery to the red "BAT" pin??????
I dont have battery cables yet so I dont have a battery cable yet for the alt and can make one if I need to.
HELP!
Old 10-19-2008, 03:08 PM   #7
Chingadera
Vehicle Year: 1984
Vehicle Make: Ford
Default
No one can open there hood and take a look at the alt wires and red coil wire and tell me where they go?
Old 10-19-2008, 10:21 PM   #8
Totalled
Totalled's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: BroncoII
I use this vehicle for: to GET IT!
Totalled will become famous soon enough
Default
__________________
1985 BII Eddie Bauer 302/C5/1350M/Aussie Locked Explorer 8.8/D35/4"ish of Tuff Country lift/35x12.50x15 MT/R's... Some assembly still required.
1992 Explorer - Sold
The Org
Totalled is offline   Reply With Quote
Old 10-20-2008, 10:00 AM   #9
Jorley
Jorley's Avatar
Vehicle Year: 1984
Vehicle Make: Ford
Default
http://therangerstation.com/forums/showthread.php?t=319
There is a link to an on-line tech manual(Haynes/Chilton) in this thread. It has wiring diagrams you can use to figure out where the wires go. If you still need some help, just let me know.
__________________
T-K 5, 31x10.5x15
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
