Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 11-03-2008, 09:49 AM   #1
Rammunition360
Rammunition360's Avatar
Vehicle Year: 1997
Vehicle Make: dodge
Vehicle Model: ram 1500
I use this vehicle for: Suckin gas and haulin' ass!
Rammunition360 is on a distinguished road
Default idle adjustment screw
can someone tell me where this is on my 83 2.8 carb, i know its "by the choke" but which one is it?
__________________
1983 Ford Ranger 2.8 5 speed 2wd
1997 Dodge Ram 1500- 5.9l 360ci magnum, 8 1/2" lift front, 6" lift back, 4.56 gears, 38.5" super swamper tsl's, true dual with cat delete and thrush glass packs...and the newest mod Ranchhand Brushguard.
Quote:
Originally Posted by lifted_Mazda01 View Post
yea jus drink a coors and find her sister,
Rammunition360 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-03-2008, 08:12 PM   #2
Rammunition360
Vehicle Year: 1997
Vehicle Make: dodge
Default
dammit, i must have the best questions because no one seems to ever be able to answer
__________________
Old 11-04-2008, 12:21 AM   #3
jjpp250
jjpp250's Avatar
Vehicle Year: 1985
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: Play truck
jjpp250 is on a distinguished road
Default carb?
What type of carb?
jjpp250 is offline   Reply With Quote
Old 11-04-2008, 02:14 AM   #4
Rammunition360
Vehicle Year: 1997
Vehicle Make: dodge
Default
motorcraft
__________________
Old 11-04-2008, 03:14 AM   #5
jjpp250
jjpp250's Avatar
Vehicle Year: 1985
Vehicle Make: ford
Default adjustment
the fast idle adj. is a hex screw up under the vac. choke, the curb idle is a on the left side were the cable hooks to, But before you do any of that you have to adj. the two mixture screws. thay are in the front of the carb and thay are probaly covered by some cabs. thay are a pain is the ass to see and more of a pain trying to adjust. I had to take my carb. off the first time just to find them. If you dont have a flexable screwdriver good luck... I pushed a piece of clear rubber hose over them, it made it alot easier to do by your self and they are easy to turn with out droping tools and burning your hands, when you have it dailed in just pull off the pieces of hose., I tried to adjust on my ranger for years, I dont drive it, It was my first truck and i just can not sell it. I just ordered a holly carb that is the direct replacment for it.
The chiltons book tells you step by step
Good Luck I hope I Help You....
Old 11-04-2008, 06:08 AM   #6
martin
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
Default
If you have the original setup on there then the idle is controlled by the idle motor on the front drivers side of the carb. Setting the base idle is a whole procedure that is outlined in the manual. If you are durasparked, then the fast idle is on the passenger side near the choke mechanism. the base idle is on the drivers side near where the butterfly shaft comes through. that's on the original carb.
martin is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
