Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 09-26-2007, 05:58 PM   #1
codered1300
codered1300's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
codered1300 is on a distinguished road
Default Vibration at 35 to 45 mph.
Hi all, i was doing my normal inspection and noticed my carrier bearing rubber was in pretty bad shape, so i replace the bearing. After replacing it i got a real bad vibration so i figured i'd take the shaft and have it balanced incase i accidently did something to the shaft while replacing the C.B. i also had all new joints installed in it. Now that took all the vibration out except for the vibration at 35 to 40 m.p.h. It does it on acceration or deacceration. I checked on motoralldata for a T.S.B. but found none. Any helpor suggestions would be helpful. Oh yeah my truck is all stock with 145,000 miles. replaced shocks not long ago. I also have newer tires that i also had balanced.
codered1300 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 09-26-2007, 06:13 PM   #2
almostclueless
almostclueless's Avatar
Vehicle Year: 98
Vehicle Make: ford
Vehicle Model: ranger
almostclueless is on a distinguished road
Default
Just because a shop balanced the tires doesnt mean they did it right.
__________________
1. MORE COWBELL!
2. Chuck Norris can win Connect Four in three moves.
3. What the H___ is an aluminum falcon!?!
4. sham....WOWWWW
almostclueless is offline   Reply With Quote
Old 09-26-2007, 09:53 PM   #3
AgPete139
09/2014 OTOTM Winner
AgPete139's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT Xcab
I use this vehicle for: DD, hauling stuff, & getting me everywhere a car can't
AgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to behold
Default
It probably didn't look this bad yet though...
Check to make sure you installed it correctly. Are you obsolutely sure you got the right part AND the model number? When I replaced the CB back in January @ 170,xxx miles, the guy @ Autozone ordered a CB for the ranger. There is actually an option #2 for the ranger, which was my specific application. It said on his screen "Bring part in for comparison."
Another is to double-check the carrier bearing connection to that crossmember on the frame. The 2 bolts (were they 12 mm?) need to be properly secured, or that vibration could occur. The seating on the driveshaft could also not be properly installed (not calling you incompetant, just check it).
The Haynes manual (IIRC) said to mark the driveshaft on the differential flange. I don't know why this would make a difference, but I marked it and put it back in the same place just to be sure. How does the slip yoke look (this really shouldnt be causing too much vibration either though)?
__________________
Green Ranger Build:
1997 Ranger Ext 4.0L 5spd BW1354M, ~7" lift Deaver springs & Explorer leaves, front D44 welded 4.88, rear Expo 8.8" autolocker, 35x12.50x15 KM2's, 1.25" DOM front bumper, shock towers + buckets, communication & stereo bits
ADD YOURSELF TO THE TRS MEMBERS MAP !!!
http://www.therangerstation.com/foru...d.php?t=128467
AgPete139 is offline   Reply With Quote
Old 09-27-2007, 09:55 AM   #4
codered1300
Vehicle Year: 1997
Vehicle Make: Ford
Default
I sent my shaft to a driveshaft shop and had them check it, (i know the guy) and they checked it and welded new weights on it so it was out of balance. I did replace the bolts that hold the CB down so i know there tight, as far as the right bearing, i also bought mine at autozone it waws the timken bearing i'm not sure of the p/n though. I guess thats my next option is to take the bearing back and try another one. Thanks for the response.
Old 09-27-2007, 10:41 AM   #5
AgPete139
AgPete139's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Default
I tried the P/N 6061 for $27.99. Seemed to fit perfectly...
You driveshaft was off THAT much? Glad you got it looked at...
__________________
Green Ranger Build:
Old 09-27-2007, 11:49 AM   #6
codered1300
Vehicle Year: 1997
Vehicle Make: Ford
Default
Hey Pete, by the looks of your rangers bottomside it looks as rusty as mine, they don't use salt in Huston do they?
Old 10-03-2007, 10:34 AM   #7
oldmantruck
Junior Member
oldmantruck's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: daily driver
oldmantruck is on a distinguished road
Default
HI,
It sounds like the carrier bearing isn't centered properly. It only moves about 1/4" so you wouldn't think it would matter, but Mine vibrated like crazy when I first replaced my bearing. When I loosened it I found that it had slipped all the way to the passenger side when I tightened it up. So I held it centred and tryed again, The vibration was reduced, but still there, so I pulled it as hard left(drivers side) as I could and now it is back to like before I changed the bearing. there is still a slight vibration, so I don't know if I need to slot mine and move it more, or If I'm getting into tire vibration now. I was too lazy to pull the wheels and was out of time, but i was amazed at how sensitive the truck was to this adjustment. I'm going to look for a one piece and swap it out.
oldmantruck is offline   Reply With Quote
Old 10-08-2007, 03:08 PM   #8
codered1300
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
Originally Posted by oldmantruck View Post
HI,
Hey thanks for the info, i replaced the originial bolts with a bolt and nut, so maybe i did the same thing, i will be sure to try that. Thanks
Old 10-09-2007, 12:54 PM   #9
Shotokan1509
Shotokan1509's Avatar
Vehicle Year: 95
Vehicle Make: Ford
Shotokan1509 is on a distinguished road
Default
I need to replace my center carrier bearing this weekend, how does the shaft come out/go back through it? Does it need to be pressed?
__________________
1995 Ford Ranger ext cab 4.0V6 4x4 auto trans
31x10.5x15 BFG A/T KO's, Warn "Jeep" hubs, leveling coils, Procomp ES9000's
2006 Mustang GT premium
2005 Subaru Legacy GT limited
Shotokan1509 is offline   Reply With Quote
Old 10-09-2007, 01:42 PM   #10
codered1300
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
No it doesn't need pressed, just use a hammer to get it off and the center nut to draw it back on the shaft. Word of advise take something and mark everything so you put it back together the same way. I had to replace the 2 bolts with standard bolts and nuts that hold the C.B. to the crossmember.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
