Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-20-2008, 09:19 PM   #1
bootleg
Vehicle Year: 1983
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: my paycheck has to go somewhere...
bootleg is on a distinguished road
Default Knock Sensor
mine is busted, and it seems an impossible-at-best little thing to find. is it really worth the search? or am i chasing a shadow?
bootleg is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-21-2008, 04:38 AM   #2
RobbieD
RobbieD's Avatar
Vehicle Year: 1984,1990,1994
Vehicle Make: Ford
Vehicle Model: Ranger, Bronco II
RobbieD is on a distinguished road
Default
Mine broke, too, and I never replaced it. Can't really tell that it makes a difference, not being hooked up.
__________________
Current:
1994 Ranger XLT SuperCab 4x2, 2.3L / M5OD. Stock, 365,000 miles.
1990 Bronco II XLT 4x2, 2.9L / A4LD. Stock, 129,00 miles.
1984 Ranger 4x2 lwb, 2.8L / C3. Stock, 148,000 miles.
Past:
1985, 1987, 1988, 1989, 1992 (all bought new).
Ranger-only driver for 22 years. TRS member since 3/18/2005.
RobbieD is offline   Reply With Quote
Old 11-21-2008, 10:21 AM   #3
enginepaul
Vehicle Year: 1995, 2001, 200
Vehicle Make: Ford
Vehicle Model: Extended cabs; one 4 door
I use this vehicle for: Driving & hauling; 300,000+ miles
enginepaul is on a distinguished road
Default
You need it if you have the original ignition.
If you're asking location: Lower Drivers side toward the rear of the block.
It sounds like you need a manual too.
enginepaul is offline   Reply With Quote
Old 11-21-2008, 11:51 AM   #4
bootleg
Vehicle Year: 1983
Vehicle Make: Ford
Default
Ha! No, I know exactly where its located...what I meant by hard to find is where to buy. I re-soldered the original, but it has seen it's last day. i don't see any difference with it disconnected...ignition is original.
Old 02-16-2012, 08:46 PM   #5
HDCowboy
HDCowboy's Avatar
Vehicle Year: 85
Vehicle Make: Ford
I use this vehicle for: DD, Hunting
HDCowboy is on a distinguished road
Default
Check out www.northernautoparts.com P/N: 5S2203
I spent about 3 months looking everywhere else, then checked out northern and found the knock sensor for 2.8ltr fords
HDCowboy is offline   Reply With Quote
Old 02-16-2012, 09:13 PM   #6
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
You may get lucky and find one at the bone yard but not very likely. I am just guessing on the price before clicking the link my guess is around $110 new if you can find it.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 02-16-2012, 09:32 PM   #7
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
Wow that is crazy cheap if you buy it be careful on how much you tighten it. The best way to test if it is working is with a timing light watch the timing marks while the engine is running have someone tap on the block with a big wrench right next to it the timing should retard with the tapping. It will throw a code if it is not working during the goose test. If all your computer stuff is working correct the knock sensor will noticeably improve performance and fuel mileage. It constantly monitors detonation and retards the timing under a load then as the vacuum pressure raises MAP it advances the timing accordingly.
__________________
Old 02-16-2012, 09:34 PM   #8
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
Dont tap on the sensor you will need a new one they are very brittle.
__________________
Old 02-17-2012, 10:38 PM   #9
enginepaul
Vehicle Make: Ford
Default
RockAuto is about $35. - as someones said - get a manual. Testing by part replacement gets expensive.
All parts need to work together for the best results.
Old 02-29-2012, 07:41 PM   #10
HDCowboy
HDCowboy's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Default
kim- i was surprised at the price as well when i ordered it. I wouldnt have even been looking for it in the first place but the kid that was working on it for me while i was not around broke it among other items costing me more $$$ for my rebuild.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
