New ride/ builder
Crashtest84
Tulsa, Ok
To give a lil background on this I got this lil beater in a trade for a bike or should I say he gave it to me so... I thought what better something to play with then a free truck so here are some pics of it and things I have done I don't have any pics from when I got it but it has come along way
here it goes the new Dana35 out of the old exploder we had thing was like new and yes it has a drop arm just not installed yet
some pics of the rear lift chevy springs and custom made hangers gave me about 6 inchs lift, I had to find brake line for the rear also.... these are brake best #'s BH49927 and BH38625 one is a f-150 4x4 line and the other im not sure
the front spring hanger moved forward 6 inchs
I also flipped the rear hangers and made a mount " no pics of the finished hanger yet "
and here are some of the lift brackets that I think are prob rough country and the new longer front lines
and last why not some wheelin pics after all this work
things to come soon 1350/1354 doubler custom radius arms "longer" and a rear 2 link for now to stop the spring wrap with the longer chevy leafs its kinda bad and some 33x12.50 somethings not sure what I wanna run just yet
things to come later 5.0 from 2000 explorer 8.8 disk 31 spline from same dana 44hp from 78 f-150 " have and must say it was a cherry find " and then some 35's
some bumper build pics they kinda suck but gives ya an idea whats going to come from the mass
simple for the rear
plans for the grille
and parts for the doubler
if there is a way to add my pics so they don't take up so much space someone let me know
looks good. Procomp makes extended stainless braided lines for Rangers, you can get them from summit.
thanks man are you talking for the front or rear? I have a guy here local that makes lines and even has cool color shielding for them I just didn't want to spend the $$ for them just yet. Cause im thinking about a 3 link in the rear with either air shocks or coil overs front and rear with the SAS and that would prob mean diff lines lol I don't think this truck with ever be done there are to many cool things todo with them
If any of you guys wanna let me in on some of your do's and don'ts as I am kinda learning as I go here. But I think I did come up with a cool way to mod a superrunner kit to make it even better for the flex crawler crowd hard to explain but I will be sure and post up some pics and let ya know how it works
both of course.
As for tricks? Is that whole front lift a rough country? If so watch the drop bracket for the passenger beam, its been known to punch a hole in the top of the pumpkin. Exended radius arms will also give you a lot of flex over the drop brackets.
Hey if you had an explorer sitting around why not swap in the 8.8 also? BTW that D35 looks brand new.
well cause the free explorer I have is a 93 and I sold the axle from it befor I got the ranger but I found the 2000 model explorer with the better stuff the other day so... I got a FI 5.0 with everything and the good 8.8 with disk brakes
sweet. wish i could find stuff like that.
ya most the time I don't get that lucky but to update some I just found me two NP 205's I went to the salvage yesterday and spent an hour just lookin around and I see a old 70's something ford off in the corner so I had to go check it out and what do you know a 205 right next to the truck and one still bolted underneath so I amd going to go back and see what they want for both of them
Well let the bumper building begin.. So I already kinda started pics will be up soon but I started front and back bumpers but if anyone can tell me about what size is a ramsey or warn 8000# winch or about how much room do I need to leave I want to prob kinda mount is between the frame rails to keep it tucked away and clean
why did you flip the rear hanger?? thats good for prerunners allows for more up travel, but for offroad you want down travel
just trying things out I guess, plus I needed about an inch or so to level the truck. I have some new hangers I made that look a lil better then the stock ones with a hole cut out of them. Plus I found out that with the shackles I made they hit the back of the hangers Also I am kinda new to the whole off-road chassis set up its way diff from street/road course stuff im used to
added some pics up top in the first post of the bumper so far and some other things
a few more pics after both ends have been welded and have one of the fillers made you are looking at the bottom side of the bumper to I should have it welded up today and maybe put on the truck and a pic of my makeshift bender
