Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-30-2007, 08:15 PM   #1
samsonitesamsonite
samsonitesamsonite's Avatar
Vehicle Year: 1993
Vehicle Make: Jeep
Vehicle Model: Wrangler
I use this vehicle for: Daily driver/weekend warrior
samsonitesamsonite is on a distinguished road
Send a message via AIM to samsonitesamsonite
Default Surging Idle
I know this problem has been beat to death but this question is a little different.
When I bought the truck 2 years back the previous owner (clamined to be an electrical engineer, but I am beginning to wonder) did a bad job wiring in a 96 OBDII 4.0 and computer into an 88 ranger... I have been fixing his problems and I have all but fixed the truck, now all that's left is the surging idle, the 96 harness calls for dual O2 sensors, but the 88 exhaust only had 1 bung, so he just hooked up the front O2 and let the pigtail for the second hang there. Could this cause the surging idle? I know Mike will most likley have a good answer on this one.
samsonitesamsonite is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 09-30-2007, 08:23 PM   #2
Bob Ayers
Vehicle Year: 1999
Vehicle Make: Ranger
Vehicle Model: St. Cab
Bob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura about
Default
Does it do it cold and hot?
__________________
"you can rant, rave, scream, shout invective, claim infinite experience,
and ultimatly deny that you are wrong until hell freezes, but you are WRONG." Alland
Bob Ayers is offline   Reply With Quote
Old 09-30-2007, 08:37 PM   #3
samsonitesamsonite
Vehicle Year: 1993
Vehicle Make: Jeep
Default
yep doesn't matter what the temp.
Old 10-01-2007, 06:27 AM   #4
Bob Ayers
Vehicle Year: 1999
Default
Quote:
If it does it cold, then it's not the O2 sensors. The O2 sensors are only used in "closed loop". I suspect the IAC valve, or the TPS. While at idle, measure the signal lead on the TPS, it should be < 900mV.
__________________
Old 10-01-2007, 09:28 AM   #5
RobbieD
RobbieD's Avatar
Vehicle Year: 1984,1990,1994
Vehicle Make: Ford
Vehicle Model: Ranger, Bronco II
RobbieD is on a distinguished road
Default
Had a surging idle problem once in my B2; it was the fuel pressure regulator. Just another easy thing to check.
__________________
Current:
1994 Ranger XLT SuperCab 4x2, 2.3L / M5OD. Stock, 365,000 miles.
1990 Bronco II XLT 4x2, 2.9L / A4LD. Stock, 129,00 miles.
1984 Ranger 4x2 lwb, 2.8L / C3. Stock, 148,000 miles.
Past:
1985, 1987, 1988, 1989, 1992 (all bought new).
Ranger-only driver for 22 years. TRS member since 3/18/2005.
RobbieD is offline   Reply With Quote
Old 10-01-2007, 09:39 AM   #6
steiner_5000
Junior Member
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Broncoii
steiner_5000 is on a distinguished road
Default
I have a similar problem to figure out so I was wondering what an IAC is?
steiner_5000 is offline   Reply With Quote
Old 10-01-2007, 09:47 AM   #7
Bob Ayers
Vehicle Year: 1999
Default
Quote:
Idle Air Control valve. Here is a picture of it (on a 3.0L), it will be located just behind the throttle body on a 4.0L:
__________________
Old 10-01-2007, 12:37 PM   #8
steiner_5000
Junior Member
Vehicle Year: 1985
Vehicle Make: Ford
Default
I really dont mean to steal this thread but this mite help. How do I test to see if the IAC is bad or maybe the TPS?
Old 10-01-2007, 08:10 PM   #9
samsonitesamsonite
Vehicle Year: 1993
Vehicle Make: Jeep
Default
I replaced my IAC and TPS. It also idles a little 'rough at times'
another question that may or may not be related to this... would an exhaust leak, right after the cat, cause the engine to run poorly?
Old 10-01-2007, 08:25 PM   #10
MAKG
RBV Technical Advisor
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
MAKG will become famous soon enough
Default
After the cat? I doubt it. It might set a MIL for an OBD-II vehicle, since there is a downstream oxygen sensor. But that sensor will say that the cat isn't working (it's not used in managing the engine).
It will also cause rust and rather embarrassing noises, so you really do want to fix it.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
