Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-02-2008, 03:30 PM   #1
SawyerRanger
SawyerRanger's Avatar
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger XLT Sport
I use this vehicle for: Everything
SawyerRanger is on a distinguished road
Default Replacing Spark Plugs
Does anyone have a guide on how to replace/check spark plugs in a 4.0 OHV(1999 model)
__________________
http://cardomain.com/ride/3134878
'99 XLT Sport Stepside 4x4 V6 4.0
SawyerRanger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-02-2008, 03:33 PM   #2
KELLY88
KELLY88's Avatar
Vehicle Year: 1997, 2005
Vehicle Make: Ford
Vehicle Model: Ranger STX, Ranger Edge
I use this vehicle for: Offroader, Daily Driver
KELLY88 is on a distinguished road
Send a message via AIM to KELLY88
Default
Pull old plugs out, put new ones in. Do them one at a time to keep the firing order right. Also a lot of people find that jacking the front end up and letting the front tires flex out to full droop makes it a lot easier to access some of the plugs from the wheel wells.
__________________
1997 Ranger STX 4.0L 4X4....... 200,000 miles and counting
4" Superlift w/ Pro Comp shocks, 33" Mud Terrains, 4.56 Gears, Iridium plugs, Warn manual hubs, Flowmaster 40
"I can predict the motions of the cosmos but I can not calculate the madness of the people." - Isaac Newton, 1727
KELLY88 is offline   Reply With Quote
Old 12-02-2008, 03:58 PM   #3
SawyerRanger
Vehicle Year: 1999
Vehicle Make: Ford
Default
So they are accessed from the wheel wells?
__________________
Old 12-02-2008, 04:04 PM   #4
97ranger4x4
97ranger4x4's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
I use this vehicle for: going from point A to B and lots of places in between
97ranger4x4 is on a distinguished road
Default
on your OHV they can be accessed from the top. The drivers side has plenty of room, but the passengers side is pretty tight. Mainly on the first cyl. That is the one that is next to the front of the truck on the pass side. Thats a PITA. Helps if you have small hands also.
__________________
97 Ford Ranger 4x4 XLT 5R55E
131k and counting
31" BFG AT KO
3.73 w Open diffs
Warn Hubs
K&N Filter
Flowmaster exhaust
Pioneer stereo
"don't **** with my truck, thats how people die."
"Do I love Rangers? Does a bear shit in the woods?"
97ranger4x4 is offline   Reply With Quote
Old 12-02-2008, 09:50 PM   #5
zedx
Junior Member
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger extended cab
I use this vehicle for: any and everything
zedx is on a distinguished road
Default
wratcheting wrench works good for that back passenger cyl.
zedx is offline   Reply With Quote
Old 12-04-2008, 02:09 PM   #6
woodyedmiston
woodyedmiston's Avatar
Vehicle Year: 99
Vehicle Make: Ford
I use this vehicle for: Work, Transportation to all-u-can eat buffets.
woodyedmiston will become famous soon enough
Default Jack up
If you are a larger person, putting the truck on jack stands, removing the front wheels, and pulling the inner fiber fender sheilds next to the engine compartment makes this a lot easier. You can also inspect areas of the engine for leaks, etc. while you are at it.
woodyedmiston is offline   Reply With Quote
Old 12-04-2008, 02:11 PM   #7
KELLY88
KELLY88's Avatar
Vehicle Make: Ford
Default
Quote:
Ya that one definitely is a fight. I try to save it for last. After that plug you need a break and it helps if that last one finishes the job.
__________________
Old 12-04-2008, 02:22 PM   #8
SawyerRanger
Vehicle Year: 1999
Vehicle Make: Ford
Default
I took a look at the locations of the plugs, and yeah, that right side definitely does not look fun, lol. I may take Woody's idea if I ever get around to it.
Instead of posting a new thread I'll just ask this here I guess. Basically the truck has been shaking very roughly when I first start it (cold start), however after it warms up it the shaking goes away.
Something similar to the shaking happened during the summer, and the result was 6 blown spark plugs, which Firestone fixed among other things like wiring for a *gracious* sum So I figured if it was plugs, I would just do it myself before it gets any worse and save some money and do it now before it got any worse. But due to it getting all new plugs, wiring etc in August, and the shaking going away after the engine warms up to normal operating temp, I figured it could be something else.
So I started reading about the MAF sensor and cleaning it, and then I went to Autozone and asked where the MAF cleaner was, and then I told him this and he said asked if there was a check engine light, and I told him that there was no check engine light. So he said maybe it could be a seal somewhere, and I should check my vacuum lines before I really buy anything. So I figured that would be a good idea.
So, summing all this up, what do you guys think? My guesses are bad plugs, vacuum lines, dirty MAF, maybe a gasket seal? And there still is no check engine light. So if anyone has any ideas that would be great.
EDIT: Just read somewhere that some companies oxygenate their gas during winter. I live in New England, so it can get pretty cold, and this all started after I filled up my truck half way with Irving Gas.. And it did seem like I was getting worse fuel mileage..
There are so many possibilities!
__________________
Old 12-04-2008, 07:15 PM   #9
Jaymz9350
Vehicle Year: 1998
Jaymz9350 is on a distinguished road
Default
That must be why I didn't have to many problems with it. I just made sure I had multiple lengths of extensions a a u-joint adapter (or what-ever that thing is called) and had minimal difficulties. It was nothing compared to when I had to change the plugs on my 90 4 banger.
Jaymz9350 is offline   Reply With Quote
Old 12-05-2008, 09:59 AM   #10
97ranger4x4
Vehicle Year: 1997
Vehicle Make: Ford
Default
yeh the best tool I think I ever bought was my wobble extension set from harbor freight. for $8 those tools have paid for themselves many times over.
It has made changing spark plugs much easier than with just my basic sockets.
I think changing the plugs on my buddies Honda civic was without a doubt the easiest job I have ever seen. I think I could acctually change all 4 plugs faster than I could fuel up my truck.
__________________
131k and counting
31" BFG AT KO
3.73 w Open diffs
Warn Hubs
K&N Filter
Flowmaster exhaust
Pioneer stereo
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
