Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Exterior
Exterior Paint, graphics, fiberglass panels, fender flares, bed covers and other body bolt on's
Reply
Thread Tools Display Modes
Old 12-12-2008, 12:00 PM   #1
flagport
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Project Restoration
flagport is on a distinguished road
Send a message via MSN to flagport
Default Ranger Tailgate Repair???
I took the tailgate off my 92 Ranger for the purpose of replacing the support cables on both sides, and to tighten up the loose latch mechanism on the right side caused by previous operators letting the tailgate fall onto the cable.
Seems I had read somewhere where you could access the handle and latch mechanisms through an access port of some type. I removed the silver center piece on the outside of the gate, but found no inspection port or way to get access to the interior of the gate. I then removed the lower bolt on the left side and found that it was only held in by a washer type nut. I loosened the top bolt on that side, but still couldn't get behind the latch mechanism to inspect anything inside the gate, or get to the latch arm between the latch and the opening handle.
Is there some trick or secret to gaining access to the interior of the tailgate where you can repair or replace some the opening/latching mechanism?
Tried a search, but little on tailgate repair.
Thanks for any advice.
Ron
flagport is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-12-2008, 12:33 PM   #2
86_cookiemonster
November '08 STOTM Winner
86_cookiemonster's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
I use this vehicle for: driving and having fun
86_cookiemonster is on a distinguished road
Default
Ron
I just took my latch out so I hope i can help you. There isn't an access panel that you can get into it to work on it, while it is in the tailgate.
What you need to do is take the latch out. There are three bolts right behind the latch on the backside of the tailgate. You take those out. Then what i did sense i replaced the entire latch, was on either side of the tailgate there are latches that actually hold it up i took the bolts out of them to give me slack in the metal rods that link them to the latch. That allowed me to disconnect the rods from the latch and slide it out.
I will try to get some pics on line about what I am talking about it will make this a lot easier to explain.
__________________
Premier Obama, said he has been to all 57 states and only has 1 more to go. He wants to be president but can't even count the number of stars on the flag/
http://www.cardomain.com/ride/2850478
Rebuilt the body,
Custom paint job,
Custom exhuast,
Spent hours with my father and lived :-D
86_cookiemonster is offline   Reply With Quote
Old 12-12-2008, 01:46 PM   #3
flagport
Vehicle Year: 1992
Vehicle Make: Ford
Default
Cookiemonster,
Thanks for the quick reply, and would appreciate any pics that you may have of the operation.
It appears that you have to take all the bolts out (an upper and a lower in each end latch, and three in the center opening handle-seven in all). This then allows you enough slack in either side to disengage one of the two rods linking the handle to the latches, which then allows you to pull center guts out thru the opposite latch hole.
If this is the case, then I guess I didn't go far enough in the disassembly process, but got worried about how everything would get hooked back up, especially the alignment of the the center pull handle with its bolt holes in order to reattach the bolts. Did you have any problem getting everything to line back up again?
I've seen an overhaul or tailgate component kit in the LMC truck catalog, so assume all these gut parts are replaceable.
Thanks again for the reply. I'm going to take the other six bolts out tonight and see what I end up with. May be further questions tomorrow.
Ron
Old 12-12-2008, 01:51 PM   #4
KELLY88
KELLY88's Avatar
Vehicle Year: 1997, 2005
Vehicle Make: Ford
Vehicle Model: Ranger STX, Ranger Edge
I use this vehicle for: Offroader, Daily Driver
KELLY88 is on a distinguished road
Send a message via AIM to KELLY88
Default
Hey cool you're in Cocoa, that's pretty close. Good luck with the latch. They can be daunting sometimes but shouldn't be too difficult.
__________________
1997 Ranger STX 4.0L 4X4....... 200,000 miles and counting
4" Superlift w/ Pro Comp shocks, 33" Mud Terrains, 4.56 Gears, Iridium plugs, Warn manual hubs, Flowmaster 40
"I can predict the motions of the cosmos but I can not calculate the madness of the people." - Isaac Newton, 1727
KELLY88 is offline   Reply With Quote
Old 12-12-2008, 02:17 PM   #5
flagport
Vehicle Year: 1992
Vehicle Make: Ford
Default
Thanks Kelly, and hello neighbor. Appreciate the support. I'm a noobie at this mechanical stuff, but with a new awsome shop and wanting to learn...with a little help from my friends on TRS from time to time.
Have a great weekend.
Ron
Old 12-14-2008, 10:42 AM   #6
86_cookiemonster
Vehicle Year: 1986
Vehicle Make: Ford
Default
Cookiemonster,
Ron
Realignment was not too hard, I am sorry to say that I do not know if i still have the pictures. One of our computer's hard drives crashed, taking a lot of my pics with it. I think they might still be on the camera but i can't find that either. I apologize,
__________________
Rebuilt the body,
Custom paint job,
Custom exhuast,
Old 12-14-2008, 09:27 PM   #7
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Vehicle Model: BroncoII
I use this vehicle for: Leaving me stranded, broke, and madder than you can imagine.
rangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nice
Default
Hmmm... My tailgate does have an access port. When you open the tailgate, and its hanging by the cables, the port faces up. It should be a rectangular panel with something like 8 sheet metal screws holding it on. Once open, you will see 2 long rods that go to each side mechanism, held together in the middle by a latch that pulls each one in when you lift the handle.
__________________
My 2.8 is about to have an out-of-body experience....permanently in liu of 4.0
rangerbum is offline   Reply With Quote
Old 12-15-2008, 12:24 AM   #8
86_cookiemonster
Vehicle Year: 1986
Vehicle Make: Ford
Default
Quote:
the latch sounds the same as what i took out of my 86. You wouldn't be able to get pics for him would you?
__________________
Rebuilt the body,
Custom paint job,
Custom exhuast,
Old 12-15-2008, 11:02 PM   #9
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Default
Quote:
I'll see if I can snap some tomorrow with my moms camera. I am a cheap SOB and still havent bought my own digital camera.
__________________
Old 12-16-2008, 08:44 PM   #10
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Default
I didnt get too much detail in my pix, but here they are:
Circled in red is the panel that you'll need to remove from the tailgate. In the last pic you can see the mechanism that will need adjusting. Btw, If your tailgate is just not staying up, the latch may just be sticking. Before you adjust anything, just spray some graphite on there and it should work smoothly.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
