Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-19-2008, 07:17 PM   #1
AzureMach1
Vehicle Year: 89
Vehicle Make: ford
Vehicle Model: ranger
AzureMach1 is on a distinguished road
Default Neutral Safety Switch
truck is a 89 ranger. how do i bypass the neutral safety switch? truck will not start by the key but i can jump the starter solenoid and it starts. im having problems with the clutch master cylinder losing presure and i have been removing the clutch master cylinder like 3 or 4 times and i think something came lose and thats why it will not start by the key. i have already replace the start solenoid and it didnt fix it. On the clutch master cylinder it has a plug in with 5 wires black, white, green, and two pink wires. i think it the two pink wires but everything i has read about says nothing about the same color wires i have.
AzureMach1 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-19-2008, 08:23 PM   #2
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
You mean the CLUTCH safety switch? I believe it's the 2 red (maybe purple, can't remember) wires on the plug.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 12-19-2008, 09:04 PM   #3
fixizin
fixizin's Avatar
Vehicle Year: 99
Vehicle Make: FoMoCo
Vehicle Model: XL 2-dr ext cab "Sport", vinyl flooring, 7.5diff 3L73, PVHubs=S.O.L.
I use this vehicle for: Sugar Sand Trails
fixizin is on a distinguished road
Default
Right, the neutral-safety keeps you from going into 4-Low, but the clutch-safety prevents juice to starter.
fixizin is offline   Reply With Quote
Old 12-19-2008, 10:47 PM   #4
AzureMach1
Vehicle Year: 89
Vehicle Make: ford
Default
yea sorry it would be the clutch safety switch but i only have a red, white, green and 2 pink wires and it 2wd if that matters
Old 12-20-2008, 09:17 AM   #5
90rangersuper
90rangersuper's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger super
I use this vehicle for: dd
90rangersuper is on a distinguished road
Send a message via MSN to 90rangersuper
Default
it has been a while since i put mine in, but its just a switch, you push in the clutch it completes the circuit, you should just have to cut the 2 wires on the switch and hook them together to complete the circuit, this is all assuming that the clutch safty switch is bad
__________________
Quote:
Originally Posted by koda6966 View Post
You could always paint a picture of Chuck Norris on your hood. Im sure that would give you about +220hp and +340 torque.
1990 Ranger Supercab, 4.0, Swapped in M5OD-R1, 1354 soon to be manual shift t-case, D35 front 8.8 rear w/ 3.55 gears
1997 F-150, 4.6, auto, 3.55 gears
90rangersuper is offline   Reply With Quote
Old 12-20-2008, 09:55 AM   #6
AzureMach1
Vehicle Year: 89
Vehicle Make: ford
Default
yea but i dont know what to wire to connect tegether. im not sure if it is the clutch safety switch but i dont know what else to try
Old 12-20-2008, 11:38 AM   #7
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Default
It's probably the 2 pink wires. If not, start jumping random wires on the plug till it works, I've had to do it before.
__________________
Old 08-10-2014, 10:49 PM   #8
surratt
surratt is on a distinguished road
Default
i am trying to bypass my nss for now while doing my 5.0 swap. The red blue wire going to the solenoid I cant figure out where it splits off to go to the nss switch...does the wire change colors before or after the nss? I may be missing a harness from the old trans or something
surratt is offline   Reply With Quote
Old 08-11-2014, 08:24 PM   #9
SenorNoob
SenorNoob's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
I use this vehicle for: Daily Driver / Road Terrorizer
SenorNoob is just really niceSenorNoob is just really niceSenorNoob is just really niceSenorNoob is just really nice
Default
FYI, that wire has several splices in it. It should be the same color at the clutch switch, the NSS, the ignition switch, and the starter solenoid. as for the routing I'd think something like this:
IGN>clutch>nss>solenoid
__________________
-Luke
My Baby
SenorNoob is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
