Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-21-2008, 08:48 PM   #1
ncsdaonex
ncsdaonex's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger
ncsdaonex is on a distinguished road
Default clutch line removal
i am replacing a manual tranny in a 1990 ranger 2.3L, the hydraulic clutch line that goes into the tranny, is there a trick to disconnect it from the slave cylinder or does it just pop out? Also how do you disconnect the hydraulic clutch line from the master cylinder?
ncsdaonex is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 12-22-2008, 09:41 AM   #2
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
There should be a small round white plastic clip on the end of the line going into the tranny, you need to push that 'in' towards the tranny with either the tool or a flathead screwdriver, then pull the line out. Sometimes it comes out easy, sometimes it's a PITA.
__________________
I hate all RBV's. I hate my Ranger most of all.
1989 Ranger build - 4.0 swap, 7.5, Dana 35 TTB, 4.56 gearing, Lockers, Electric power steering
1976 Fiat 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Old 12-22-2008, 09:59 AM   #3
dogboy
dogboy's Avatar
Vehicle Year: '93
Vehicle Make: Ford
I use this vehicle for: DD'er and weekend wheeler
dogboy will become famous soon enough
Send a message via MSN to dogboy
Default
Like BlackBII showed, you need the removal tool (the easiest way, I think), and it should come off.
If it doesn't, just keep wiggleng the hell out of it, in and out, and side to side, and it will eventually come out. Mine was a real pain when I did it.
__________________
'93, 4x4 Ranger, ext. cab, 4.0L, M5OD 5spd swap, Doubler, D30 SAS w/Lockright, Explorer leaves, 3" body lift.
4Door Crew Cab Build
DD: '94 ext cab 4wd, 5.0l 6" lift and 35's
dogboy is offline   Reply With Quote
Old 05-26-2009, 07:14 PM   #4
desertredneck
desertredneck's Avatar
Vehicle Year: 2000
Vehicle Make: ford
Vehicle Model: ranger
desertredneck is on a distinguished road
Default
does anyone know how to get the other side off
desertredneck is offline   Reply With Quote
Old 05-26-2009, 08:18 PM   #5
97fordrunner
97fordrunner's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
I use this vehicle for: Weekend Wheeler
97fordrunner will become famous soon enough
Default
I believe there is a roll type pin that holds the other end into the clutch master cylinder, you may need to pull it out of your truck, mine is right under the brake booster and hard as hell to get at, not sure if yours is the same
97fordrunner is offline   Reply With Quote
Old 05-27-2009, 09:25 AM   #6
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Default
Yeah, pull the master cylinder out, two 10mm bolts, under the brake booster. Then you have to punch out the roll pin and pull the line out.
__________________
1976 Fiat 131 build
1990 BII-R.I.P.
Old 05-27-2009, 09:47 PM   #7
desertredneck
Vehicle Year: 2000
Vehicle Make: ford
Default
what a pain in the a$$. i dont have any bolts on the engine side of my truck. its a 2000 2wd 3.0
Old 06-01-2009, 06:39 AM   #8
desertredneck
Vehicle Year: 2000
Vehicle Make: ford
Default
i figured it out i had to remove the whole master cylinder to take out the line it wasent hard at all
Old 07-17-2009, 03:49 PM   #9
privateeraz
Vehicle Year: 1998
Vehicle Make: ford
privateeraz is on a distinguished road
Default master
so how does the mastr cylinder come out ???
privateeraz is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
