Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Forced Induction
Forced Induction This forum is for ALL Turbo and Supercharger topics. This includes the 2.3L Turbo topics. Forum sponsored by Banshee Supercharger
Reply
Thread Tools Display Modes
Old 01-13-2009, 12:20 PM   #1
skyy_4life
skyy_4life's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: Driving and hobbie
skyy_4life is on a distinguished road
Default How Much PSI
i was wondering what is the max psi i can run on stock internals with my turbo because i wanna up the boost some. i have stock 2.3l 94 ranger. everything has been upgraded except internals but how much PSI can i safly run with stock internals. only post if u really know what your talking about. thanks.
__________________
1994 ford ranger 2X4 2.3 Turbo
Lowered 4"-5" HX35 on 25psi, GReddy Frontmount
1988 turbocoupe 5spd- minor mods-Daily Driver.
1996 Ram 2500 Cummins CCLB-lifted on 37s
skyy_4life is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-13-2009, 05:39 PM   #2
Sevensecondsuv
Sevensecondsuv's Avatar
Vehicle Year: Many
Vehicle Make: All Fords!
Vehicle Model: Most of what Ford Made in the 90s!
I use this vehicle for: Life
Sevensecondsuv is on a distinguished road
Default
What kind of EFI are you running?
If it's the stock ranger set up, you're running on borrowed time. If you modified the MAF and have 19's, I'd still be scared of anything more than 5 psi. If you are running the turbo electronics and fuel injectors, I would guess you could run 8-10 PSI. Just be super careful and listen for detonation. The stock pistons simply will not withstand detonation while under boost. Anything over 10 I'd be too scared to try because if the A/F gets off even slightly, the pistons will be toast.
__________________
2011 Ford Ranger 2.3 5-spd; 2001 Ford Ranger 2.5 5-spd;
1992 Explorer 4wd 5-spd; 2000 Ford Excursion 6.8 4wd;
1995 Ford F-250 4wd 4.9 ZF-5 D60 SAS;
Past: 1990 Ranger 2.3 Turbo
Sevensecondsuv is offline   Reply With Quote
Old 01-13-2009, 08:09 PM   #3
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
It depends on whether or not you will port the intake and heads. If you do that and the engine flows a greater CFM then you will max out at a slightly lower PSI. If you flow 300CFm your turbo could push 5PSI through the engine. However if you bump it up You will achieve greater power with Less boost. An engine that pushes 450CFM will claim the same Horsepower as the 300 but at 3.5 PSI. Its a basic desription but something to think about.
My personal recommendation is take the heads and intake to a good machine shop. Have them ported, portmatched, polished etc. (Dont over do it) Then when you put your turbo on the truck start with a lower PSI. But no matter what you should be able to push 4-5PSI safely. Anything more needs to be done step by step on a dyno tuning while increasing. Otherwise your subscribing to the big bang theory.
Also go find an '84-85 SVO Mustang motor, I dont know about the '94, but some years are a complete match for the crank and pistons.
feellnfroggy is offline   Reply With Quote
Old 01-13-2009, 10:23 PM   #4
anupaum
anupaum's Avatar
anupaum will become famous soon enough
Default
I've run 5 psi on stock pistons for a long time without trouble. I still have good compression on this engine, too!
__________________
robert luis rabello
Adventure for Your Mind
http://www.newadventure.ca
anupaum is offline   Reply With Quote
Old 01-23-2009, 10:08 PM   #5
birdmanslopy
Vehicle Year: 1994
Vehicle Make: Ford
birdmanslopy is on a distinguished road
Default
n/a internals dont go past 8 you got t/c internals be like me and do 20
birdmanslopy is offline   Reply With Quote
Old 01-30-2009, 01:15 PM   #6
skyy_4life
skyy_4life's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Default
well i know some guys with stock internals that run 10-12 with no problem... i plan on getting head gasket and connecting rods and boosting like 30+
__________________
Old 01-30-2009, 02:23 PM   #7
littleme13
littleme13 is on a distinguished road
Default
just push 15psi then when everything blows you have an excuse to rebuild the bottom end. make sure and report back with what psi everything let go....lol
most everything i have ever seen is 6-7 psi on stock internals. certain engines get away with more some cant handle that.
littleme13 is offline   Reply With Quote
Old 01-30-2009, 02:34 PM   #8
rurouni20xx
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Everything
rurouni20xx is on a distinguished road
Send a message via Yahoo to rurouni20xx
Default
when you push 30 psi thru it post the youtube video of the head gasket blowing/head blowing up/piston through the oil pan, i wanna see destruction!!! honestly tho, even a supra twin turbo w/ thicker cylinder sleeves and forged internals cannot go above 22 psi w/o rebuilding it every 5 wide open throttle runs, i doubt seriously that a stock ford block could take that much psi. after completely rebuilding the internals and have everything setup for large boost i wouldnt go above 20 psi. stock internals i wouldnt go above 8 for durability, the 10-12 psi guys will be rebuilding real soon i can almost promise you that.
rurouni20xx is offline   Reply With Quote
Old 01-30-2009, 06:58 PM   #9
Sevensecondsuv
Vehicle Year: Many
Default
The stock ford 2.3 turbo block is well proven to endure 20 psi for well over 200,000 miles and then it's usually the top end that finally throws in the towel. Currently, my 35 lb/hr injectors are pretty maxed out at 16-17 psi. My next step is a tuning setup and bigger injectors. Then I can join the 20 psi crowd.
With an upgraded bottom end, E85 and/or methanol injection, and a good tune, 30 psi is doable.
But on a ranger bottom end with cast pistons (rods and crank are the same a stock turbo motor) definately keep the boost low.
__________________
Old 01-30-2009, 07:11 PM   #10
rurouni20xx
Vehicle Year: 1993
Vehicle Make: Ford
Default
why e85? it is thinner and contains less potential energy, you use twice the e85 to produce the same amount of power as gasoline, plus at the price its just not cost effective. i was reading thru a flex fuel vehicle owners manual and it clearly stated that you will have to go thru two tanks of e85 to get the same mileage as a single tank of gas to get the same mileage. methanol on the other hand is hardcore stuff, treat that w/ respect or youll be rebuilding an engine in a hurry. that and i doubt seriously he wants to spend 7 dollars a gallon to fill up cuz he cant just put regular gas in the trk after tuning it for methanol. if this is a daily driver or show vehicle id stick to regular gas as its readily available anywhere and is cheaper/more cost effective. if you are trailering it to the track and are running it for timeslips go w/ methanol, but i wouldnt even think about putting it on the street cuz youd be stuck at the house siphoning gas every time you got low. just something to consider and my .02
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
